3.2Q - Erratic idling issue - coilpacks?
V6Pete Nov 17, 2009
  1. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
    A couple of weeks ago I went to take my car out one night, and the car was idling really badly - jumping between about 500 and 1000 revs. The car was showing just 10 miles of fuel left, so I thought it could be that, so I went out in a different car. The next day all was fine.
    The problem happened again earlier this week - strangely again when low fuel, then fine since.
    Today, with a brimmed tank, the problem came back - it feels ok when at speed, but at low revs and slow speed it's incredibly jerky and again idling really roughly. The engine management light also came on a few times (mostly flashing, but once solid for a bit).
    My initial thoughts were either MAF sensor or coil packs. I've had MAF sensor failure on a couple of cars before, and it wasn't intermittent like this, which made be think maybe coil packs?
    I can't get around to taking it to the garage until this time next week for plugging in, and just after any ideas in the meantime?
    Pete
  2. TAC
    TAC 3.2 V6 Burble... hmmmmmmm
    300
  3. V6Pete
    1,491
    Cheers for the link; I remember that thread from a couple of months back, but hadn't kept up with the updates...
    My issues seem different though - it's at lower revs, and seems more pronounced. I guess it's good news that the engine management light came on, as hopefully that may point us in the right direction.
  4. paddy
    paddy Audi=No fault code, no idea
    5,168
    136
    Its not our problem in the link above......that is at 2k revs as the cams advance.
    I would think if it was a coil pack the revs would stay the same as the ECU compensated for the drop in revs....auto tick over etc. Also odd to get 2or 3 coil packs go at one together like that....
    some one in northants must have vagcom ??
  5. V6Pete
    1,491
    But if not coil packs.... hmmm. Anybody else ever had similar issues?
    If there's a local guy with VAGCOM that would be great, otherwise I've not got a lot of miles to do in the next week so can just book it in for Wednesday at my local garage with diagnostic gear.
  6. if the management lights flashing most likly the coil packs ... i had the same problem and two of the coil packs had cracked thats 1 and 2...
  7. V6Pete
    1,491
    Yeah that goes along with my gut feeling.
    I'm going to run it over to APS on Friday to plug in, and they've got coil packs on the shelf if it is that. From what I described on the phone, they reckon coil packs also.
  8. edition
    edition Active Member
    1,426
    Let us know how you get on!
    How much are the coil packs?
    Are the non VAG ones worth going for or will they not last.
  9. V6Pete
    1,491
    Will do mate. I think he said £28+VAT each.
    I wouldn't buy non-VAG unless they come out of the same factory, as it's not really the part to skimp on.
  10. edition
    1,426
    Yeah i was thinking the same.
    Still £200 to replace them all hey!
    How many miles have you done now Pete?
  11. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    IVE HAD A COIL PACK GO AND JUST ONE WAS REPLACED >> Ive never had a problem since just use vagcom see which pack it is and replace it ....I wouldnt do them all
  12. V6Pete
    1,491
    Yeah another £200, an expensive couple of months just for small bits and pieces. Last month was about £1000 for tyres, alignment and CV boots!
    The car has done 62Kish.
  13. edition
    1,426
    My c/v boot has weaped abit of grease (where the boot meets the driveshaft) but is not split..... Had yours split?
  14. paddy
    5,168
    136
    Sorry Pete...didnt notice the bit about the engine light...So basically i was talking rubbish..
  15. V6Pete
    1,491
    When I bought the car earlier in the year, the MOT mentioned one of the outer boots was oozing. When it went in for a service a couple of weeks later, at the service they pointed out that both nearside front outer AND inner boots were leaking. Anyway being lazy I did nothing for about 6 months, but when the car needed alignment doing I thought it was the time to do the boots. So I bought the boots, booked into the TT shop for the work and when they got it up on the ramp, discovered that another inner boot had gone, so I needed 3 in total! D'oh. One of the outers was cheap pattern **** which explains the leaking. But they were well and truly split and had dumped at least half of their grease all over my undertray. Messy.
  16. V6Pete
    1,491
    No worries mate, I talk **** most of the time. Or so everybody tells me.
  17. V6Pete
    1,491
    Coil packs ok.
    Timing chain not ok.
    Not a happy chappy.
  18. edition
    1,426
    Bummer!
    Stretched they think?
  19. V6Pete
    1,491
    Indeed bummer and indeed stretched they think.
    Audi are c*nts; this is a known problem happening to loads of these engines at this sort of age, but no point in even arguing with them, the car is nearly 6 years old so they'll tell me to piss off I'm sure.
    £1000 I've been quoted to fix, not really what I need :(
  20. edition
    1,426
    Is that for the same chain that has stretched? I.E. it will happen in another 65k miles?
  21. V6Pete
    1,491
    I really don't know. If it happens again at 120k miles it'll be somebody elses problem though!
  22. edition
    1,426
    Hmm very poor.
    I'm sure people were getting a contribution to the cost out of Vw for R32's, might be worth a try? Although they might not like your car too much due to it being modded...
    Yours got full Audi dealer service history?
  23. edition
    1,426
    Also what do your figures show on the VAGCOM blocks for timing?
  24. V6Pete
    1,491
    I can try for a contribution, but if that pays towards their silly main dealer labour rates and extra hours they like to add, then it'll be more money than a fix by an independent.
    Engine mods are just a back box, remap (they won't see) and an air filter (standard box in at the moment) so I'd like to see them argue that as a factor...
    Yep FASH.
  25. V6Pete
    1,491
    Not been VAGCOM'd.
  26. edition
    1,426
    Would be nice to get those figures before they strip it I guess...
    Not sure how conclusive they are tho....
  27. V6Pete
    1,491
    They used their own diagnostic kit, rather than VAGCOM, but were pretty confident that was the problem due to various symptoms.
    Just waiting to hear back from my local Audi dealer where I stand as far as goodwill goes. I still think it would be cheaper to go independent, whatever deal Audi offer. It winds me up though, as I shouldn't be £1000 out of pocket due to a known design fault.
  28. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,213
    399
    Sorry to hear that mate and welcome to the club. I've been without mine over 3 weeks now while it's done.
    Audi quoted me £2k to change the chain and Audi uk wouldn't give a goodwill gesture because the tensioner was changed by an independant, as a first attempt at fixing it. My car is an 05 with full Audi service history and 50k miles.
    It definately is a common fault though as there are far too many cars across the vag range with the same problem and the chain and tensioner have been revised numerous times.
    Best of luck at getting it sorted out!
  29. V6Pete
    1,491
    Cheers dude, but not really a club I wanted to become a meber of ;)
    Audi quoted me £2162 for the repair including a whopping £800 of parts (APS said £350 of parts would do the job!). I think Audi want to replace half the engine.
    I have been offered a goodwill contribution of £500, but not going to pay £1700 to them, so will argue this all I can.
    As far as I'm concerned, I bought a product that has been maintained by Audi dealers when advised it needs to be by Audi, and a badly designed part has failed prematurely. This IS their fault, but getting them to admit it is a different story.
  30. -Ju-
    2,213
    399
    Yeah, it sucks mate. Fortunately for me I noticed the problem when I bought the car from the dealer and have pushed them to fix it. It's been a struggle but I can see light at the end of the tunnel now and should have mine back sometime next week.
    It is getting worrying with so many cars recently being diagnosed with timing chain problems but saying that, we are still waiting for the first confirmed fix.
  31. V6Pete
    1,491
    Have a look on the R32 forums, there's a lot on there.
    APS said they had one in last week with the same problem, and have now done a few timing chains on this engine. It's certainly more of an issue than VW UK are currently admitting.
  32. -Ju-
    2,213
    399
    Yeah I know mate, I had a mk4 R32 with a stretched timing chain and the word was the problem was sorted mid 2004, that's why I went for an 05 A3 3.2 Doh!!!
  33. V6Pete
    1,491
    C*nts, how the **** can VW insist it's not a known problem?
