3.2 jacking point
clem2192 Sep 23, 2010
  1. clem2192
    clem2192 Member
    174
    All,
    Planning to get my new wheels on this weekend, have done a search on the forum but cant find the answer so.......
    Where is the jacking point / best place for jacking the 3.2 using a trolley jack?
    Ryan
  2. diggerbucket
    diggerbucket New Member
    24
    Bump, I'd quite like to know this too.
  3. Vertigo1
    Vertigo1 Well-Known Member
    3,380
    541
    If you check the sill closely you'll find a couple of arrows pressed into the metal which show you were to put the standard jack - I'd just put the trolley in the same place under these arrows tbh.
  4. davej_anderson
    davej_anderson Member
    261
    careful there, if you put the trolley jack nearest the bodywork you will crease the body work, the correct loading point is on the arrow
  5. BACKSTEP
    BACKSTEP New Member
    27
    Also ideally use a rubber block or wood as the sill can get damaged especially 3.2 is very front heavy.
  6. diggerbucket
    24
    That can't be the typical place to put a trolley jack, surely?!
  7. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,196
    382
    It's where I always put it!
  8. edition
    edition Active Member
    1,426
    I always used the car jack is I was putting it on stands as like you say there doesn't seem to be 2 areas...
    Watch using that standard jack they look lethal!!
  9. NHN
    29,300
    1,702
    The reason the oem jack has the channel in is it is purposely designed to fit around the ridge/crease you can see hanging down, thus no damage down, but the jacks arent exactly the best to work with, but to date havnt caused me an issue, but I do use a trolley jack these days & the correct place is indeed marked by an arrow on the bottom edge of the car front & rear, as already advised a piece of rubber is advised so as to not damage the underside.
    I do use stands on the front purely for safety even if the trolley jack is meaty as hell, anything can fail at anytime, so I always like to have 2/3 safety precautions in place.
