3.2 fsi quattro cam chain
saxonblue Nov 21, 2013
  1. saxonblue
    saxonblue Member
    298
    15
    OK, I got the 3.2 fsi Quattro, and its got a cam / timing chain, now one garage told me that there's nothing I need to do with it, its a life of the car thing and will never need adjusting, or any kind of work doing to it.
    BUT, I just saw an older program of 5th gear, on it was a golf with the same 3.2 engine , Jason from 5th gear says, there ace but look out for the chain going funny, there should be something in the service history telling you its been done, if not it could cost you £1000.
    what do I need to do, if anything..........
    confused!!!!! plz help:think:
  2. JimmyH
    JimmyH Active Member
    374
    73
    Yes I saw that also, he mentioned about the tensioner failing.
  3. saxonblue
    saxonblue Member
    298
    15
    yep, that he did, should I be worried??????
    mine seems to be fine, but it have got 124000 on the clock
  4. imotepify
    imotepify Member
    226
    14
    Any updates on this thread?
  5. igor781
    igor781 Member
    The issue is with cam tensioner in all fsi/tfsi VAG engines.The solution as i find out is avoiding long life oil service and change oil every 7500 miles
  6. imotepify
    imotepify Member
    226
    14
    So what oil do you guys recommend?
  7. igor781
    igor781 Member
    Well in my a6 3.2 fsi i am using Liqui Moly 4200 5W-30 or Fuchs Titan gt 5W-30.I do max 7500 miles.
  8. saxonblue
    saxonblue Member
    298
    15
    I have it serviced every 12 months, or about 7.5k-8.5k miles without fail, the guy I use is a vw guru and only uses the oils, fluids you would get from vw / Audi, so I no its good stuff in there,
    he told me not to worry, and said trust me, you would know if the chain was going faulty as you would hear it for ages first
  9. igor781
    igor781 Member
    Oils from Vw/Audi dealers are castrol or quantum so very average overpriced stuff.I prefer to pay bit extra for very good oils from Valvoline, Lm of Fuchs.I service the car with super guru ex racing driver who also used to build engines for one of the Uk racing Championships
  10. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group s tronic
    3,937
    732
    I think the key to the long life of any engine is to move away from the stupid long life servicing, I change my oil every 6 months or 5K miles, and just use the quantum stuff. Also don't buy the oil from the VW/Audi dealers, it's a dam sight cheaper from TPS.
  11. saxonblue
    saxonblue Member
    298
    15
    The oil he uses is valvoline. Or at least that's what's in the big tub
    I top up with castrol or half odds own stuff
