3.2 flat spot @ 2000rpm?
grebowski Feb 27, 2008
  1. grebowski
    grebowski Member
    30
    I've recently noticed that my car has developed a flat spot in the rev range around 2000rpm its gone into audi today for its first MOT and I've asked them to investigate, anyone else had this problem?
  2. Wes G
    Wes G Member
    444
    I had this problem buddy... I found it to be a plunger that had fallen\come off the inlet manifold, if you lift up your bonnet and look down at the front right side of the plastic manifold kind of between the airbox intake and the manifold you will see a unit with a plunger that just clips onto a ball\socket joint on the side to opperate the valve inside the manifold, might be worth a look?:icon_thumright:
  3. edition
    edition Active Member
    1,426
    Hi,
    Yep mine had the same. I would decribe it as like a step in power.
    Went in 2 times for it, the first the replaced some wiring to the air mass sensor, that helped but didnt fully solve it.
    Second tinme they said they put a new map on it and that solved it and ist been fine for a month since :)
  4. grebowski
    grebowski Member
    30
    That’s exactly it, a step in power, I’ll have a chat with the service manager when I go to collect it later
    Cheers for the quick replies lads , I knew I wasn’t the only owner with this problem.
  5. RobB
    RobB Member
    317
    Would be good to hear of solutions to this - I too have exactly the same issue (on both 3.2's I have owned). Feels like you have just whacked the accelerator at about 2,200 or so, and makes you look like a learner.
    It's going in for creaky front suspension soon so would be great to also go armed with suggestions and other experiences of this before my warranty runs out.
  6. RobB
    RobB Member
    317
    Further question - mine is a manual. Also driven a DSG 3.2 for a few thousand miles and don't remember having the same problem.
  7. edition
    1,426
    Mines a manual also. 05plt if that matters.
    Mine is now got a lovely smooth band of power from 900r.p.m to red if u wanted :)
  8. RobB
    RobB Member
    317
    Edition - is your still ok after a few months now? Mine is booked in next week and I mentioned the revised map per your post. The dealer is waiting to hear back from Audi UK on a solution. Would be great if you could let me know the dealer that fixed yours or find out exactly what they did in case they dispute the problem next week. Any info much appreciated.
  9. edition
    1,426
    Hi there,
    Yes seem good still.
    From what i got told they put more current software map on it. Before doing this they did find what they thought was a poor earth near air mass meter but this didn't cure it.
    I have found mine does run slightly smoother when pulling from low revs on better fuel i.e super or v-power (those premium types) and im sure its not just in my head.
  10. RobB
    RobB Member
    317
    Great - thanks for this. They are being quite helpful and pro-active so far, so I will see what happens next week.
  11. edition
    1,426
    Let us know how you get on.
  12. IN-A3
    IN-A3 Member
    457
    I had an update to the engine ecu in feb part no for cd is 820 906 961 B.
  13. RobB
    RobB Member
    317
    Cheers for this. Can I just double check that this was for the same flat spot / hesitation / surge issue on the 3.2?
    It's in tomorrow for a couple of days so I hope they have the answer.
  14. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,214
    399
    This seems exactly like what mine has got. What was the final outcome, software remap or something else?
  15. paddy
    paddy Audi=No fault code, no idea
    5,168
    136
    No problem with mine. 37k miles, 2004.DSG , Interested to see the cure because i expect mine will go down sooner or later..
  16. baz1985
    baz1985 Member
    49
    Luckily no issues with mine. I wonder if it is related to changes in the factory maps across build dates.
