3.2 engine mounts
wickyianr1 Oct 30, 2010
  1. wickyianr1
    wickyianr1 Member
    106
    hi all found out what the knocking noise on left hand bends its the engine moving to the right and causing the top engine bracket of the mounting to touch the inner chassis leg we can see were its touching the body anybody elsehad this problem.:sob:
  2. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,416
    516
    Just checked mine mate and it's fine. Does look quite tight down there though so I can see it being a problem if the mount's are worn.
  3. wickyianr1
    wickyianr1 Member
    106
    cheers ju just been rocking the engine from side to side lots of play
  4. JRutter
    JRutter A3.2
    I put in aftermarket poly mounts and although the noise and vibration did go up, I'm keeping them for the solid feel in corners.
  5. wickyianr1
    wickyianr1 Member
    106
    can anyone tell me how many mounts there are and are they easy to fit yourself
  6. wickyianr1
    wickyianr1 Member
    106
  7. JRutter
    JRutter A3.2
