3.2 DSG Stalling,cutting out and hunting
marmite Mar 5, 2010
  1. marmite
    marmite Counting the Tesco Club points
    1,101
    My mates A33.2 DSG has just started to cut out and hesitate for no reason
    the vehicle has gone into Audi and there was a Airmass fault logged
    it cuts and stalls at idle and when he slows down at lights it cuts out, intermittently
    New air mass sensor fitted and the car was fine for a while but then started faulting again
    the car plays up more in bad weather and when cold, or seems that way!
    Fault logged in the ECU for air mass but this is new and been donor tested with another vehicle
    earth points checked and cleaned but fault still preasent.
    Audi Tech have mentioned replacing all the inlet manifold seals and throttle body seals, fuel injector seals
    Has anyone had similar issues?
    Notes on the searchn of this about camshaft adjuster faults stored, but after running VAGCOM on it tonight there is just a Airmass fault
  2. akash_sky1
    akash_sky1 Active Member
    1,181
    yet another 3.2vr6 problem thread..eek
  3. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,196
    383
    Loads of problems with A3 3.2's on here mate, some with the symptoms you describe and some with the hesitation only circa 2k rpm.
    Have a search around, but I think you'll find the only one to have a similar problem cured is V6Pete and his involved 3k worth of work!.
    My first 3.2 had the symptoms you describe, but it was the earth point which you've already discounted!
    Best luck and if you do find a fix then please post the results!
  4. Hellz
    Hellz Geordie Racer
    378
    I had the exact same problem, I say 'had' as it hasnt happened in a good while now (engine stalling that is). A few others experienced the same issue and tried various things to remedy the problem - theres some info in this thread of the problems I and others had as well as attempts at resolving the damn thing - http://www.audi-sport.net/vb/showthread.php?72043-Engine-cut-out-ECS-ESP-lights-on
    Since I had the ECU reset to 'factory settings' by AUDI I havent had the stalling issue although I have seen one instance, in six months or so, of 'hunting' but the engine didnt cut out and no error was logged afaik.
    Good Luck getting it sorted mate.
  5. paddy
    paddy Audi=No fault code, no idea
    5,152
    133
    Can only wish you good luck mate, its criminal how Audi don't accept these 3.2 problems. if they were to even acknowledge a problem they would be in for millions of £ like Toyota which is why they keep stom
  6. Hellz
    Hellz Geordie Racer
    378
    I agree Paddy, as much as I love the car I always have a nagging in my head every time I drive it of 'somethings gonna go wrong'...
    AUDI should have done some serious investigation on the 3.2's as the problems are common in symptoms and widespread - not much chance of a recall / courtesy fix now though!
    I find it odd that it isnt so common in the R32's / TT's with the same engine though - at least from the limited info I've been able to find.
    Frustrating :(
  7. marmite
    1,101
    Cheers guys for your replies
    It is going into a great indi rac-london.co.uk, really recommend them, they have looked after my RS recently and aer vey good
    Once Steve at RAC has worked his majic I will do another update
    They said there is a small crack poss causing a leak at the flexi joint on the exhaust buy the manifold
    will give update later
  8. paddy
    5,152
    133
    Cheers marmite..would be good if you can let us know how he gets on.
  9. -Ju-
    2,196
    383
    That's exactly the same thing I have noticed on mine! (right hand side looking from the front)
    I noticed it last weekend and have been investigating it over the week too see if it's been affecting the lambda readings.
    Currently got it pasted up to a degree with gun gum, but I still think it's leaking a little.
    Unfortunately the replacement pipe includes the downpipes, cats and first silencers so not an easy or cheap fix
  10. marmite
    1,101
    Car is cutting out and hesitating even on part throttle at idle
    no fault codes stored
    so now armed with vagom logging every joureny we shall see what comes up?
    May get the throttle body cleaned out and readapte it
  11. marmite
    1,101
    Mates car came back from Audi Specialist and Audi Dealer with the following:
    Tiny hole in the flexi pipe but specialist claims that the Lambda sensor is before the hole so should not cause this issue. The Now be sure that the car does have the same as you are posing but also sometimes stalls. It idles at between 600 and 640 which is below the man spec. Most of the time it sits at 600 post the choke. Man spec is 650. This may be causing it to stall ? Thats with the air con off !!
    So first question and suggestion:
    DO all of you that have this issue, also have a small hole in the flexi pipe ? If so have you had it replaced with an Audi or performance version exhaust from the manifold to the end pipe ?
    Audi and Specialist have a tech fix for this that requires the inlet manifold seal and injector seals to be replaced. My only concerns with this suggestion is 1) its expensive and 2) the issue is very random and sporadic on the cars. The specialist states they would expect an air leak to cause consistently bad running issues ?
    Checkout the strange Lambda values on Bank 1 below. Do you all have this ?
    Summary:
    Ok, many of us have had lost of kit changed but no one has said if they have had the etch fix I was advised carried out ?
    The precise issue it fixes is "Sporadic MAF behaviour" faults in the log. Audi found that when the MAF was replaced and returned to them, most of the suspected faulty MAFs were fine, so they suggested this fix for the inlet manifold seal and injectors.
    Does anyone know a good after market exhaust from the Manifold to the end pipe ?
    Lambda is all over the shop on this car on one bank but that may be the hole in the exhaust?
    At Idle: Bank 1 is broken. Note sure if this is the flexi pipe tiny hole?
    RPM Lambda Bank 1 Lambda Bank 2
    600 -0.8 0.8
    600 -1.6 0.8
    600 0 0.8
    640 2.3 0.8
    600 2.3 0.8
    640 1.6 0.8
    640 5.5 0.8
    640 8.6 0.8
    640 7 0.8
    600 6.3 0.8
    600 7 0.8
    680 7 0.8
    640 5.5 0.8
    640 0 0.8
    600 2.3 0.8
    600 6.3 0.9
    600 4.7 0.9
  12. edition
    edition Active Member
    1,426
    Did you get any further on this marmite?
