3.0tdi turbo on 2.0tdi
HIGGINS Dec 7, 2011
  1. HIGGINS
    HIGGINS Member
    528
    15
    Ive been looking at the GTB2260VK turbocharger which has been converted to use a vacuum actuator. It also comes with the intercooler 2.5" outlets.
    Is this a good upgrade? Has anyone done it?
  2. HIGGINS
    HIGGINS Member
    528
    15
  3. nally
    nally MPG the new BPH
    2,104
    34
    no idear would it not have huge lag?
  4. HIGGINS
    HIGGINS Member
    528
    15
    not if its mapped correctly
  5. MattyW19
    MattyW19 Member
    401
    Wouldn't the internals have to be changed because of higher pressure?
  6. HIGGINS
    HIGGINS Member
    528
    15
    only thing im thinking of is a mani, 3" down pipe, clutch and map
  7. Adam.
    Adam. Meow.
    662
    34
    A few boys are running this turbo on the 1.9 ARL's with a custom manifold IIRC.
  8. HIGGINS
    HIGGINS Member
    528
    15
    got any links or anything buddy?
  9. Adam.
    Adam. Meow.
    662
    34
  10. Adamantium
    Adamantium Member
    250
    13
    What are you trying to achieve?
    There are some very decent turbo options available that are designde to go straight in without adaption.
    Am not sure exactly what the point is when there's a plethora of decent hybrids available that can flow as much air as the stock engine can handle without producing any extra lag. What more could you want, apart from perhaps a lower price tag?
  11. Hi there,
    it depends on your power goals, if you want to go beyound 250hp you should user a GTB2260VK don't be fouled that it's a GT22 it has the 3rd gen vanes so the spool would be more than decent of a 2.0 tdi. For a daily driver i would use a GTB2056VK that at 2000rpm can do 1.3 bars or even better if you wannt to limit to 230-240bhp go for a GTB1756VK and your lag will be almost 0, much better response than the stock turbo that is a 1st generation VNT :)
    LE: you don;t need to change the stock Intercooler that is the same as the GTI has. If you want to be 100% safe you can buy some bosio uprated injectors to protect the cylinder head that is prone to leak coolant.
  12. S3AMK20VT
    S3AMK20VT Member
    170
  13. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
  14. micasb
    micasb Member
    327
