3.0tdi Quattro auto fault code.....
NotNormal May 18, 2013
  1. NotNormal
    NotNormal Active Member Team Nano Grey VCDS Map User Audi S3 quattro s tronic
    319
    59
    I keep getting this fault code coming up ..... Any help anyone ?
    symptoms are, driving in sport, progressive acceleration, 3rd to 4th and 4th to 5th, top end of the revs it rumbles/judders for a couple of seconds then sometimes drops into the next gear, sometime I have to back off the throttle then reapply to get it to engage the next gear
    I've had the box checked, the oil is of good quality and no water ingress - the oil level is satisfactory too
    trying to get a heads up here.....any help ?
  2. NotNormal
    319
    59
    There are no other fault codes in the car either, nothing in the engine ecu ------ :/
    Ignore the age of the fault, this is an old picture i took - the fult has happen 5 or 6 times today on a run back from Blyton
  3. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    its the gearbox ECU check the wiring /plugs as well.
  4. NotNormal
    319
    59
    any hints on locations for the g/box ecu ?
    thanks
    tom
  5. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    under the floor?
  6. gupsterg
    gupsterg Active Member
    348
    It is in the transmission ... only accessible with the sump of gearbox removed ...
    You can access elec.harness on outside of gearbox ...
  7. NotNormal
    319
    59
    Turns out it was an issue related to the fuel system
    Every two seconds after the low fuels pressure code flashed up the gearbox fault was logged
    Then the low fuel pressure fault vanished from the ecu
    The cars had a complete fuel system bar the tank and on fuel pipe as per a TPI from Audi - I've done 1000 + miles and its faultless
    the cars slightly better on fuel and the performance is back
    gupsterg likes this.
  8. gupsterg
    348
    Thanks for update ... happy [​IMG]...
