Hi, My 3.0TDI Cab has exactly the same issue, (similar mileage 77k) I bought it like it unfortunately lots of white smoke though it does clear as soon as the engine is under load, and it is intermittent, and as you are finding a horrible dieselly smell before and after the white smoke. I know a Audi mechanic, I had diagnosed it myself as injectors, but he doubted my diagnosis and wanted to put it on the diagnostic machine in his workshop, as he thought it may of needed a software update. When he brought it back he stated that the software was up to date and he had measured the values of the injectors on the diagnostics and he said everything was ok, but suspected EGR Valve/EGR Cooler issues. I was still not convinced having already cleaned my EGR and all the inlet trac out of carbon, I took it to a recommended BOSCH Diesel service centre, they plugged it into a diag machine and again confirmed all was well with the injectors, as this white smoke issue is very intermittent and it wasn't smoking at the time I still wasn't convinced I revved the engine a couple of times and thankfully it started to smoke, the guys colleague noticed and came over and straight away said that it had faulty injectors, on closer inspection there were three values from the injectors that were reading differently to these others but as they were from opposing cylinders wasn't seen as an issue, it was only this other guys previous experience of the ASB engine that told him the injectors. This actually confirmed what I found when plugged it into VCDS after finding an exert from an Audi tech. report on a forum. So it turns out I have 3 dodgy injectors, they recommend all six to be cleaned and tested at £20 each, this £20 is refunded on each injector they have to replace, and £240 each for a new injector. I have tried running good branded fuel and loads of injector cleaner through it and even a Terraclean hoping if the injectors were simply dirty then it might sort it but with no joy. If you want the contents of the Tech report I will post it up. Sorry about the lack of paragraphs etc but it seems I have forum/browser issue as I did put them in.
