3.0 TDI A6 Buyers Guide
PeteS Aug 12, 2011
  1. PeteS
    PeteS Member
    40
    Hi
    I am looking at buying a 3.0 TDI A6 over the weekend. Any advice on things to check would be helpful. Thanks in advance.
    PeteS
  2. crispin
    crispin Member
    167
    good choice!! Check full service history..they are pretty bullet proof, just check well looked after and that all the buttons work.
  3. snapdragon
    snapdragon New Member
    19
    If you have a laptop, buy VAGCOM VCDS HEX CAN for £100 ish.
    I did this to find faults, but turned up other problems.
    I have looked at two A6s so far and both were found to be clocked when I ran a scan.
    It seems they clock them every year before the MOTs so that the mileages on only MOTs look OK.
    e.g. The mileage was 11000Km lower this month than in march, similar story since 2009.
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 C HW: 4E0 035 111
    Component: CD-Changer H44 0340
    Revision: 00000000 Serial number: AUZ5ZBD4025313
    Shop #: WSC 00000 000 00000
    VCID: 193244C1AE83
    2 Faults Found:
    02261 - Data Medium
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 191
    Mileage: 222028 km
    Time Indication: 0
    Date: 2011.10.13
    Time: 20:03:46
    Freeze Frame:
    Text: 0000840E
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 7
    Fault Frequency: 7
    Reset counter: 198
    Mileage: 233369 km
    Time Indication: 0
    Date: 2011.03.04
    Time: 07:32:27
  4. yendall24
    yendall24 Member
    571
    i have often wondered about clocking before the first mot i suppose this carry on makes it even more important to make sure it as a full main dealer service history or can this also be scammed . i hope you reported the clocked car to the local trading standards office at the end of the day its theft and fraud and needs stamping out
  5. 1animal1
    9,978
    good info on the clocking.....
    Im curious why you are paying £100 for vcds leads though? when a £15 lead off ebay and their freeware will scan fault codes for you?
    I had one of these and used without issue before I bought the full version for £250 (cheapest your likely to get it!)
  6. snapdragon
    19
    Good point about the availability of cheaper VACOM clones, I wanted to use later versions of the software which requires the genuine lead to act as a licence key.
  7. 1animal1
    9,978
    Im interested to know what you have for £100 over my genuine lead?
  8. snapdragon
    19
    I have had a look, seems the price of what i have is $349 now :note:
    Ouch. Back in the day I had the free version 4.19 (before VCDS Lite) and most labels were blank and things in the channels were not labelled. There was a warning not to scan the airbag as it could go off on some models and one couldn't reset V6 TDI service indicators or read the mileage from the engine ECU. Maybe the cloned ones are better these days?
  9. 1animal1
    9,978
    no idea, i only know my £15 ebay jobby could do some logging, all fault code reading/erasing, and that was pretty much the lot..... :)
  10. jojo
    28,885
    3,539
    Interesting, do these faults just come up as part of a scan, or did you have to look for them?
  11. snapdragon
    19
    Autoscan scans all modules one by one.
    Not trying to hijack thread but it is a useful question for buyers, are all front wings and bonnets supposed to be aluminium?
    The A6 2006 brochure suggests so, but a few I have looked at are obviously steel as they have a bit of brown rust on chips or on the wing where loadstones hit it at the bottom and on further inspection look like body shop replacements anyway.
    I keep forgetting to take a fridge magnet to test them with.
    I have to say, these cars and their sellers seem to suffer much higher levels of 'dodginess' than any other I have looked at.
  12. snapdragon
    19
  13. elan2s
    elan2s Active Member
    343
    40
    I believe only the S6 and RS6 have aluminium wings and bonnet. As to A6 sellers being dodgier than most, I suspect it may have something to do with how well Audi builds its cars and thus even those with a few years and high miles behind them are still very good condition and therefore prime candidates for clocking
