2nd wmi nozzle performance decrease???
daz-20vt
Hi guy just outofninterest what could cause a decrease in performance after fitting a 2nd nozzle to my s3?
K04 hybrid set up.
Was ibviously hoping for an increase lol.
Ok how do i adapt this? Lol
Im not convinced my wmi is working well anyhow
Not been party to many but nozzle size and boost setting for turning WMI on need playing with to get the best from it...
Have you tried logging IAT's with meth on and off?
Daz did you use the CM throttle spacer?
If so did you drill out the thread so the nozzle sits flush? I had to do this as it was no where near and would have caused the 2nd nozzles flow to hit the side wall of the threads and possibly drip
Is it worth upping the boost pressure switch setting if you have 2 nozzles bill?
I remember you saying you set mine to 12 psi? But at the time only had post intercooler nozzle
Cm adaptor has been modded so nozzle is set flush
Yep its no power till 4k min and then its less than it was before.
I had wmi installed with 1 nozzle and mapped by bill
2nd nozzle fitted after
Im not convinced mines ever worked right.
Mine is the newer pump
What should the psi on the pump be set at guys?
Its always liked throwing loads of meth in!!
80
7K
889
866
9
837
