2G MMI 2013 & 2014 Update Disks
ScottishA4B9 Mar 1, 2014
  1. ScottishA4B9
    ScottishA4B9 Well-Known Member Team Daytona Audi A4 saloon S-line owners group TDi
    3,119
    815
    Hi all,
    I have the 2012 update disks installed on my 2G MMI.
    Does anybody know if the 2013 or 2014 disks offer any additional features other than map and functionality updates?
    There are plenary of non-genuine disks for sale on eBay and I see the new 2014 disks are now available.
    Many Thanks
  2. ScottishA4B9
    3,119
    815
    Anybody?
  3. dt-tdi
    dt-tdi Member VCDS Map User
    191
    20
    Try N8 (Nathan)on here, he may be able to help you out.
  4. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,000
    764
    I've just gone from 2013 to 2014 and cannot see and real differences, however with the 2014 maps it's now split onto 2 DVD's so if your traveling around Europe make sure you have both discs..
    DVD 1
    Germany, Switzerland, Andorra, Belgium, France, Gibraltar, Great Britain, Ireland, Liechtenstein, Luxembourg, Monaco, Netherlands, Austria, Portugal, Spain.
    DVD 2
    Germany, Switzerland, Albania, Bosnia and Herzegovina, Bulgaria, Denmark, Estonia, Finland, Greece, Italy, Croatia, Latvia, Liechtenstein, Macedonia, Lithuania, Montenegro, Norway, Austria, Poland, Romania, San Marino, Sweden, Serbia, Slovakia , Slovenia, Czech Republic, Hungary, Vatican City.
  5. dt-tdi
    191
    20
    I've been making enquires with N8 about updating my 2006 maps on my RNS-E and the updated 2014 version still doesn't give full post code access which is a bit disappointing.
  6. B5NUT
    4,000
    764
    You will never get full post code on RNS-E MK1 & 2 or the 2G MMI system.
  7. ScottishA4B9
    3,119
    815
    Mores the pity! You would think it would be possible to do. If theres not extra features, then I won't bother updating to the 2014 discs.
  8. ScottishA4B9
    3,119
    815
    Has anybody installed the 2014 discs yet?
  9. B5NUT
    4,000
    764
    Yes, ran the 2014 discs on my old 2G setup without any problems. Other than updated maps there is extra functionality.
  10. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,300
    392
    Its worth the update just for new maps otherwise you might as well not have SatNav as you will find a lot of missing roads.
  11. ScottishA4B9
    3,119
    815
    What's the extra functionality?
  12. B5NUT
    4,000
    764
    Sorry that should have said no extra functionality.
  13. mancdan
    mancdan Active Member
    497
    51
    How do I know which version of Sat Nav/Audio setup is in my car?
    i.e do I have 2g MMI or something else??
  14. B5NUT
    4,000
    764
    Take a picture of the screen but press the car button then setup and go into version
    mancdan likes this.
  15. mancdan
    497
    51
    OK here we go:
  16. B5NUT
    4,000
    764
    You have MMI 3G Hard disk version.
    mancdan likes this.
  17. mancdan
    497
    51
    Thanks B5NUT. Is it worth getting the up to date 2014 sat nav disc? I believe it has 2012 all ready installed.
  18. B5NUT
    4,000
    764
    Both your map and firmware are from 2009, and you won't be able to install the latest maps with out updating the firmware first. You can update both the firmware and the maps yourself as there are download available on the internet, but there is always a risk of a failed update that will stop your system from working. For the map update it not just the case of putting a new CD and updating, the MAP's for your MMI system are 30GB in size and require installing, you then also need to activate the MAP's which is dealer only and costs £££, there are map activation hacks that you can download but some of them are malware that will brick your MMI.
  19. mancdan
    497
    51
    Thanks B5NUT, sounds like a non-starter then and I will just leave it all alone.
  20. B5NUT
    4,000
    764
    If you know that your doing it's easy enough, and there are plenty of information out there, you just have to know what is good advice & what is bad! There are sellers on ebay that will provide you with the firmware, maps & activation but again if something goes wrong with the update then you need to know what your doing as the seller won't pay for the repair. If it not broke and it not causing any problems (missing road etc) then leave it alone or find a retrofit company that will do the work for you at a price.
    mancdan likes this.
  21. mancdan
    497
    51
    Thanks for the sound advice B5NUT. As you say, its not broken and I don't use it that often, so best to leave it be.
