247 to 270+ Stage 2 ( how much faster will it feel?)
S3 JOHN Jun 26, 2012
  1. S3 JOHN
    S3 JOHN Member
    310
    Hi all ,
    Im booking my car in for a AMD stage 2 map in the next couple of weeks as im ready now . Im running 247bhp at the moment and have been told that i should be getting 270+ after with the mods im running .
    Will it feel like a massive difference ? as from standard to stage 1 made me smile for a long time !
    Any info would be great
    Many thanks
    John
  2. knoxie
    knoxie K4OXE
    619
    15
    what stage one map are you running?
    im running AMD stage one, silicone tip, big filter, forge 007 an made 267bhp
    it had a random map on before from a previous owner that was running around 240bhp
    you can definatly feel the difference :)
  3. s33nyboy12
    s33nyboy12 Well-Known Member Team Ibis Team V8 Audi R8 s tronic
    1,488
    203
    In general and in my experience, any gain of + 15bhp you can FEEL the difference.
    So in short yeh, you will notice good difference.
  4. jojo
    28,944
    3,598
    It's more about the gains in torque for stage2, hopefully you will see over 300lb/ft torque! And you will benefit most with in gear accelleration!
  5. S3 JOHN
    S3 JOHN Member
    310
    I had a stage one Amd map but it was completely standard when i had it done and it was nearly three years ago now so not sure if there software is better now .
    I have a full jetex exhaust ,3" tip , 3" dp+200 cell sports cat and a green panel filter so so i hear i should get a good result from stage 2 .Cant wait!
  6. <tuffty/>
    21,689
    4,119
    Stage 2 can lift peak power a bit but mostly its mid range you gain so will feel more drivable overall... its not just about peak power, its area under the curve... Stage 2 prerequisite mods are essential to get the benefits from a stage 2 map... these mods allow the engine to run cooler so that more boost and ignition timing can be dialled in and the ecu won't be pulling it back out due to the engine getting hot... elevated IATs, EGTs and flow restrictions all make the engine run hotter and the ECU will decrease load, increase AFR and pull timing to prevent the engine nuking itself... decent FMIC, 3" DP and sports cat plus other higher flow capable items like the Badger5 TIP, Jetex filter etc will all help....
  7. S3 JOHN
    S3 JOHN Member
    310
    elevated IATs, EGTs What do these stand for / mean ?
  8. <tuffty/>
    21,689
    4,119
    IAT = intake air temps... high intake air temps reduce air density and subsequently power... also promotes pre-ignition/knock due to increased cylinder temps
    EGT = exhaust gas temp... high EGTs are just generally bad... typically mean high cylinder temps which will melt things in the engine and promote cracking of metal components such as manifolds and turbo hotsides... ECU counters by chucking in more fuel as this helps cools things down but will also kill power..
  9. S3 JOHN
    S3 JOHN Member
    310
    Cool Iv learnt sometime today . Many thanks
  10. Gops
    3,198
    666
    Have you considered rods for stage 2? Only reason I say this is because ppl have had Rods go with stage 1! thats what's stopping me from going stage 2!
  11. superkarl
    superkarl MAN OF STEEL
    9,571
    2,464
    pussy
    Big Bang Yam and actualeddie like this.
  12. Neru
    Neru Member
    129
    9
    haha isnt the standard rods good for 300bhp?
  13. <tuffty/>
    21,689
    4,119
    Its not power that bends them its torque and as said before the age/mileage and how the car has been driven plays a part in to when the rods may go...
    Anyone considering doing anything more than stage 2 levels of tune should seriously consider changing the rods...
  14. Westy
    Westy Well-Known Member
    17,443
    1,105
    I'd recommend rods too. I just feel better knowing that they are done.
  15. JtotheD
    JtotheD Active Member
    907
    26
    would this be why my fuel economy is suffering whilst i'm running stage 2 without an FMIC?
    I have ordered the AH Fabs V2 so should only be a matter of time until I can turn things up a bit as running stage 2 with the boost and things turned down a bit at the mo.
  16. <tuffty/>
    21,689
    4,119
    It would only affect your fuel economy if you were booting it everywhere lol..
    No... driven normally even having a stage 2 with out a FMIC won't adversely affect fuel economy any more than it would normally... if you are having fuel economy issues I would imagine it was something else...
  17. Westy
    17,443
    1,105
    Do you reset your trip computer when you fill up so that the MPG calculator is back to 0.00?
    I spoke to Rhubarb at GTI Inters and he had low 20s MPG and I told him to reset the calc and it sorted it.
  18. <tuffty/>
    21,689
    4,119
    I don't rely on the DIS for accuracy these days... although with teh motorway trips to GTI last weekend I actually managed a personal best of 27.8mpg (80mph cruising on the motorway)
    I use fuelly (Fuelly | Share and Compare Your MPG) to track my mpg... works pretty well tbh
  19. Westy
    17,443
    1,105
    Put a 4 bar FPR in and watch your DIS MPG increase by 15% lol
  20. badger5
    9,556
    2,028
    lupo managed 34mpg... which is a best for years..
    map tweaks have done the trick - yay
  21. <tuffty/>
    21,689
    4,119
  22. jojo
    28,944
    3,598
    I've got a vision of you tweaking the map on the M6 on the way home Bill with a laptop on the passenger seat! :laugh:
  23. <tuffty/>
    21,689
    4,119
    Nah... he was too busy annoying Porsche drivers :)
  24. badger5
    9,556
    2,028
    lol @ porka driver on m6 sliproad..
    cant even outrun a vw lupo, I mean ffs - lmao
    only 1bar boost in lupo @ time also... haha
  25. superkarl
    9,571
    2,464
    how did you do on the strip at inters bill?
    a load of us missed your run.
  26. badger5
    9,556
    2,028
    i was shyte... lol
    only got one run cos of the accident... 6.x - 60 and 14.x 1/4 I think.
    mostly ruined by me.. lol... 2nd gear launch felt ok, wheelspin being the enemy and swift gearchanges on the lupo are not the best.. which I confirmed by not being unable to find 3rd when trying.. and afterwards realising I was on middle boost setting anyhow not the 300+bhp level..
    with my vbox over xmas it did 5.5sec 0-60 on a frosty night, so confirms my poor performance at inters.
    Sadly I did'nt get a 2nd go due to the accident..
  27. JtotheD
    907
    26
    I do that but I work out my own economy anyway and use fuelly.. I average low 20s but that is purely town driving so I suppose that's ok..
  28. JtotheD
    907
    26
    Ok cheers.. Having thought about it I suppose my economy is average .. Especially for the type of driving I do - just around town all short journeys..
  29. dre_S3
    dre_S3 Member
    756
    39
    Talking about the rods if they do go what other damage will it do to the car or will the rods just need replacing sorry if it's a dumb question not very clued up with inner engine work myself but most other things on the car I would take on myself :)
  30. Westy
    17,443
    1,105
    I used to get 22mpg for just town driving. Now I get 34 doing 50 mile journeys to and from work mainly in 6th gear!
  31. <tuffty/>
    21,689
    4,119
    Depends... could be lucky and get a small bend near the small end... anything beyond that generally scraps the block... worst case is it punches a hole in the block and takes out the crank too... new short engine required after that... assuming it doesn't take the head with it too... which could happen
  32. Hammy999
    Hammy999 Member
    175
    Its a big gamble not to get the rods done with that sort of power. Problem is the rods are not that cheap to replace with the labour to fit them and the price of the rods themselves. Then again replacing an engine is not that cheap either if a rod goes!!!
  33. dre_S3
    dre_S3 Member
    756
    39
    so how much we looking to buy and get the rods changed :uhm:
  34. Hammy999
    Hammy999 Member
    175
    About £440 for the rods £80 for head bolts around £800+ labour for fitting plus £100 for miscellaneous bits. So roughly £1500 give or take.
  35. dre_S3
    dre_S3 Member
    756
    39
    wow not a cheap one then may speak to a family member if he wants to take it on if i decide to do it, labour would be alot cheaper that way for me. Only want about 280 bhp 300 lbft but i know thats still pushing it with standard rods, would rather do things properly and not f up my engine at such low mileage only done 48000 and i payed extra for that when i bought the car so makes sense
  36. S3 JOHN
    S3 JOHN Member
    310
    Hi all
    so im all booked in for my amd stage 2 next sat , Happydays! Im running a 3" tip , relentless 3" DP and 200 cell sports cat , full jetex system and a green cotton panel filter . Also upgraded to 2.0l tfsi coils not sure if this will make any difference ?
    Whats your guesses on the BHP after the remap?
  37. Westy
    17,443
    1,105
    I think you'll get 270 but I also think you'll be needing a FMIC pretty soon. My AITs were quite high even on a stage 1 map.
  38. S3 JOHN
    S3 JOHN Member
    310
    Yeah FMIC will be my next mod to do . Im always on the look out for one up for sale .
  39. superkarl
    9,571
    2,464
    put the map off till the fmic is on imo.
    you'l end up with a more aggressive map (more boost) so more heat, which the stock stuff wont handle well, while it might end up feeling quicker for a brief moment, itl soon run out of power like stage 1 does through the rev range.
  40. S3 JOHN
    S3 JOHN Member
    310
    Its to late now all booked in and paid . I only want a couple of months of fun anyway as im off cycling from Melbourne to Perth in oct for three months then fly from Perth to NZ for a year so FMIC is a mod for when i come back . Also want to hybrid when i come back and start chasing some big numbers .
