245mm wide tires
Maxwell7 Jul 6, 2004
  1. Maxwell7
    Maxwell7 New Member
    9
    After taking several measurements, I have concluded that 245/40/17 tires mounted on 17X8 wheels will fit an Audi TT Quattro. There is a clearance of 20mm from the inside of the front tire to the strut with wheels at full lock; therefore going from 225mm(stock) to 245mm should work because only 10mm of the 20mm added will extend inward towards the strut. The rear appears to have generous clearance.
    I am fairly confident in my measurements, but I would still like to know if anyone has had real world success with this extra width.
    Max
  2. dunk
    dunk Member
    770
    255/35/18 will fit under an s3, so probably will a tt too.
    only problem is the awful tramlining and loss of handling - dont do it.
  3. Maxwell7
    Maxwell7 New Member
    9
    Any other opinions/experiences?
  4. dunk
    dunk Member
    770
    not sure whether you need to know if it will fit, or if its any good.
    they will definately fit
    they wont improve the car.
  5. Maxwell7
    Maxwell7 New Member
    9
    dunk,
    I understand what you are saying, but to base my decision on your isolated experience would be foolish- I would like to hear from a variety of owners. Perhaps your tramlining is the result of an alignment issue (too much toe out), maybe your loss of handling resulted from your larger/heavier wheels or lowering the car too much. They fit under your S3- you cannot be sure that they "definately" fit under a TT. Has anyone actually experienced sidewall rubbing?
