245/40/18 tyres - OK to run on the rear?
DALE_AVANT May 11, 2012
  1. DALE_AVANT
    DALE_AVANT Member Audi A4 Audi A3 Audi Avant Owner Group Team Brilliant Black TDi
    620
    21
    Hi guys.
    Would 245/40/18 tyres be fine for the rear on my Avant Sport? I have two spare so I may as well use them if I can.
    Many thanks
  2. pink.teg
    pink.teg Member
    170
    Wat size rims are they
  3. DALE_AVANT
    620
    21
    8J x 18".
    ET43.
    The width should not be an issue but I think the rolling radius will be out a little
  4. quattrojames
    14,050
    578
    Rolling radius shouldn't matter on the rear, assuming your car isn't a quattro.
  5. DALE_AVANT
    620
    21
    Nah it FWD. I meant in relation to space in the rear arches over bumps and such
  6. pink.teg
    pink.teg Member
    170
    In that sence ... No problems
    i have a Quattro
    and have 234/40/18 on front
    245/40/18 on rear and it's fine
    was on RR and the bloke that set up my map asked !
    and said the read out was fine !!
  7. jbcalvin
    jbcalvin Member
    691
    21
    245 is the width of the tyre and will not have any effect on the rolling radius, 40 profile is right for 18" wheel, you should be fine with these, it's only 10mm wider than a normal 235....
  8. DALE_AVANT
    620
    21
    245/40 has a larger rolling radius than 235/40, as the 40 represents a percentage of the 235/245.
    So 40% of 245 = a bigger overall tyre than 40% of 235 (iirc)
  9. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
  10. BahnStormer77
    BahnStormer77 BahnStormer
    2,773
    59
    FWD should be fine to run different rolling radius tyres, but you are putting a lot of completely pointless strain on the quattro differential by doing what you're doing... it'll run fine on RR or on the road, but it just works the differential constantly...
  11. pink.teg
    pink.teg Member
    170
    K
    will wack the 235's back on ASAP then
    Cool save them for the dry summer days ...
  12. BahnStormer77
    2,773
    59
    other thing to bear in mind for anybody who's got FWD and wanting that hot-rod stnad with slightly chunkier tyres on the rear... it may seem really obvious, but wider tyres = more grip... so the back will grip more and increase understeer...
    One of the later model Polo GTI's (2008?) has NARROWER tyres on the back to give the car a more neutral balance on the limit :)
  13. quattrojames
    14,050
    578
    I 'think' RS3's do too.
  14. avantsport
    avantsport DIESEL DOG
    Will 245/40/18 on 8j et 43 go on the avant sport front and rear as i have a full set from an a6 but unsure if they will fit.
  15. archemist
    archemist Active Member VCDS Map User Audi S3 Team Brilliant Black
    247
    31
    they'll be about 2% bigger (RR / circumference ) than standard 215/55/16 baseline
    Tyre Calculator - Alloy Wheels - Specialist supplier of alloy wheels and tyres packages, Fast Delivery, Buy Online.
    gives you loads of option for tyre width / size.
    don't know about width (+5mm both in and out) but if people are running spacers and 35 et's then the ouside 'rim' shouldn't be a problem
    don't know about the 5mm nearer inner wheel liner though.
