235/45/17 TT alloys on A3 8L?
Sniper210010 Mar 11, 2013
  1. Sniper210010
    Sniper210010 New Member
    17
    Hi all,Had a quick search but couldn't find a definitive answer.Would 235/45/17 audi TT wheels and tyres fit ok on my A3 8L?PCD is 5x100 so I know that's ok, I'm more concerned about rubbing etc etc...Thanks!
  2. superkarl
    superkarl MAN OF STEEL
    9,571
    2,464
    234/45 is too big a profile so your speedo would be out.
    if you're lowered considerably it may rub, depends tho
  3. Prawn
    11,613
    3,597
    Speedo difference is so marginal you can 100% ignore it,
    standard tyre size is 205/55/16, total diameter 631.9mm, 235/45/17 has a total diameter of 643.3mm.
    The speed will in theory under read by just 1.8%, but seeing as all speedos over read by 5-10% anyway it'll actually make your speedo MORE accurate, not less :)
    I run 235/45/17 on mine and have no clearance issues at all.
  4. niallh
    niallh Member VCDS Map User
    213
    I ran 235/45/17 on my TT wheels. I had no issues and my car is down on coils. Dare say handling was a little better over 225's
  5. harvey01
    harvey01 Member
    523
    9
    i run 235,40,18s with a 32mm offset had to space the front due to being proper low
  6. Sniper210010
    17
    so in your experience would you say im better off leaving it at stock height or lowering it? if so how much should i lower it by so that it looks good but is minimum fuss.....
  7. harvey01
    harvey01 Member
    523
    9
    well mine is so low you can just about put a finger between the tyre and the arch so fit them and play with the hight
