235-35-19 to 225-40-19
g60leigh Aug 5, 2008
  1. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    I have been trrying to get some replacement tyres in 235-35-19 but they are like hen's teeth to get at a decent price, guy at the tyre place said try 225's as they will fit no problem and are cheaper, I have sourced a set of 225-40's at a nice price but am wondering if anyone can think of a reason there will be a problem? cheers
  2. stapo69
    stapo69 All hail the mighty quattro!
    969
    If your 19s are like mine, fitting them in the arches is a bit tight. With a 225/40 you will be losing a little in the width, but gaining in height cos of the bigger profile. Why not a 225/35? A little bit skinnier, but the same profile, also seem a bit more of a common size, in case you pop one and need to replace.
    Have a look on here, dozens of tyres at pretty good prices: http://www.mytyres.co.uk/start.html
    Can get a decent deal from the shops on ebay too.
  3. g60leigh
    1,674
    207
    I have a set of MICHELIN PILOT SPORT 2 225/40's for £120 so going to give them a go
    wonder if the stretch will ofset the height?
  4. jcb
    jcb Active Member
    4,132
    13
    why would you lose width? they are both 225mm wide.
    the 35 and 40 profile is not a measurement its a percentage of the width.
    35% of 235 = 82.25mm wall height
    40% of 225 = 94 mm wall height
    that is close to 12mm top and bottom on the wheel height, do you have 12mm's worth of space between the current tyre and bearing carrier upright? I know I don't.
    probably explains why they are less common or not popular.
  5. jcb
    jcb Active Member
    4,132
    13
  6. Oranoco
    Oranoco Well-Known Member
    3,991
    407
    Just done a quick search and am now glad I opted for 18's. £172 a piece for Toyos :ohmy:
  7. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Yes your gearing will be well screwed deviating from the stock rolling radius by that much. That's 5% and the maximum recommended is 2.5. Even your old tyres were only just inside the 2.5%.
  8. jcb
    jcb Active Member
    4,132
    13
    slows you down too!
