210 or 225 How do i know ?
mattyboy199 Nov 23, 2005
  1. mattyboy199
    mattyboy199 Well-Known Member
    1,885
    As above how can you tell without putting it on the rollers ?
    Matt
  2. god_thats_quick
    2,507
    The engine code in either the service book (inside front cover) or on the engine on in the boot around the spare or even on the V5 but the DVLA are a bit rubbish sometimes.
    You are looking for APY, AMK or BAM for a UK car, APY and AMK are 210 BHP(154kw) and BAM is 225BHP(165kw).
    you could also have a look in the FAQ at the top of the forum, there's some useful info.
  3. AndyMac
    9,832
    45
    The power should also be printed on the sticker in the spare wheel well (in kW as above)
  4. mattyboy199
    1,885
    so it being a facelift would make no difference ?
    Matt
  5. madvw
    madvw Active Member
    2,489
  6. mattyboy199
    1,885
    what about manufacture dates ?
    Matt
  7. Cupramax
    Cupramax Uber pimp meister
    457
    The 10th character of the VIN is the model year so a 1 would denote 2001 etc...
  8. monty77
    monty77 Member
    391
    [ QUOTE ]
    Matt
    [/ QUOTE ]
    Nope ... mine was a facelift, AMK engine code = 210BHP .. they both chip to the same power anyway /ubbthreads/images/graemlins/wink.gif
    The engine code is also stamped on the engine block, on the left IIRC.
    Adam
  9. mattyboy199
    1,885
    when did the facelift occur then ?, was the 225 engine introduced from a certain date onwards ?
    Matt
  10. RichA3Turbo
    5,089
    March '02 onwards i believe!
  11. JimmyTheSaint
    JimmyTheSaint New Member
    26
    So what should a healthy 210bhp engine make @ the wheels? Mine's going into Awesome for a pre-remap power run this sunday... just want a ballpark figure as the Awesome rollers can't give accurate flywheel figures (apparently).
  12. RichA3Turbo
    5,089
    130bhp @ wheels i think...
  13. mattyboy199
    1,885
    jus checked my car on my lunch break & i m a BAM (which is nice to know ;-)).
    Matt
  14. mattyboy199
    1,885
    also could someone tell me where peak power is (in the rev range).
    Matt
  15. marctwo
    marctwo Member
    410
    Peak power on mine was 6000rpm+ IIRC. Peak torque around 3800rpm.
  16. god_thats_quick
    2,507
    I think peak power on most S3's is around 5,800rpm from memory
  17. Ryanc
    Ryanc Active Member
    1,321
    No difference in 210/225 anyway,a healthy s3 should make 160bhp at the wheels.
    You can also tell a bam because it has vvt and a solenoid on top of the engine.
  18. god_thats_quick
    2,507
    Hi Ryan,
    All S3's have VVT, there is just a difference in operation from the APY to the later engines. APY is mechanical where as AMK and BAM (and the other international engine codes) are electronic. /ubbthreads/images/graemlins/tongue.gif
  19. Ryanc
    Ryanc Active Member
    1,321
    I used to think that but the apy doesn't have it,i know.
