2014 Spark Plug Thread For Audi S3 8L
AudiLondon Apr 21, 2014
  1. AudiLondon
    AudiLondon Member
    95
    2014 Spark Plug Thead (Audi S3 8L)
    Right, First of all Id like to say I have read quite a few threads on this forum about which spark plugs to buy for a 99-03 reg Audi S3. The main contenders seem to be NGK and Bosch spark plugs.
    What NGK Offers:
    The two most raved about spark plugs for a standard 210BHP model of the S3 are the BKR6E (Copper) or the BKR6EIX (Iridium).
    The copper version is said by many to be better for our turbo engines but Iridium as we all no will last a lot longer.
    What Bosch Offers:
    The main Bosch spark plug that people seem to speak about on here are theBosch Super 4 which is a 4 tip iridium spark plug.
    These dont seem to be as popular as the NGK's but look like there more readily available through Halfords and such.
    So given the little bit of research I have already done. Could anyone advise me on what spark plugs I should buy for my 2000 reg Audi S3 210BHP in the year of 2014 as all the other threads seem to be quite dated. I have a Halfords round the corner from me and they have Bosch Super 4's in stock so was very tempted to buy them today until I started reading the threads.
    I don't want to adjust the gap myself or modify my coil pack in any way. I just want a straight replacement for the current plugs at the moment.
    So Get recommending!! You don't have to be an expert in mechanical engineering.. Just post which spark plugs you fitted in your car, How they performed and how long they have lasted.
    :readit:
  2. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,187
    Bk7re.
    Gops and cammage08 like this.
  3. JimS3
    JimS3 Active Member
    736
    72
    Bosch Super 4 are the last plugs I would fit. The spark will only jump one gap, the 4 electrodes are all gapped slightly differently so as one wears out it will move on the next. Aimed at longevity rather than optimum performance.
    If your car is standard go for the BKR6E. If its mapped go for the BKR7E.
    You will not find a better plug for the money, the ONLY down side is they don't last as long as the iridium, but you can buy many sets of the copper plugs for the price of the iridium. Its not the end of the world to change them every 10 - 15K or so!
  4. Freeman_1986
    Freeman_1986 Member
    169
    21
    I went for the copper BKR7E. Don't mind having to change them more often. Fraction of the price compared to the iridium's, and obviously with copper being a better conductor of electricity........
    As Kevin Baker says: "no brainer"
  5. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Gops likes this.
  6. AudiLondon
    AudiLondon Member
    95
    Nice replies lads.. So as my car is standard ill order up 4 of the NGK BKR6E plugs
    Are these the right ones?
    NGK Spark Plug B BKR6E 6962 X 4 | eBay
    If they are not would somebody be able to send me a link to a website or the correct ones on ebay.
    Thankyou
  7. Gary_808
    Gary_808 Member
    166
    To echo jim,
    Bosch super 4's are ****e,
    Erratic spark, been noted to cause det, my tuner wouldn't touch my car with them fitted,
    Good for longevity of the plugs but **** for performance.
  8. AudiLondon
    AudiLondon Member
    95
    Definitely steering clear of the super 4's :salute:
    As my car is standard like I said I will go for the BKR6E (Copper) Would some one be able to give me a link to buy them please?
  9. samc182
    samc182 New Member
    12
    I just ordered some laser platinum's for the next service on my car. Any reason there not in the running?
  10. jojo
    28,997
    3,649
    I run the factory spec NGK Iridium spark plugs on mine with no issues. My current ones have done almost 20k miles.
    I can understand the regular 6k mile changes using the copper versions if your car is in a high state of tune, but for standard power, why try and fix something that's not broke? Of course, if we're after a cost saving, then that's another reason for using the copper versions.
  11. AudiLondon
    AudiLondon Member
    95
    I am just taking the advice of you guys on here mate. The BKR6E versions are what people are recommending. Would you be able to provide a name or part number for the spark plugs you recommending?
  12. AudiLondon
    AudiLondon Member
    95
  13. Freeman_1986
    Freeman_1986 Member
    169
    21
    Change the 6 to a 7
  14. jojo
    28,997
    3,649
    The part number you already quoted in your original post. Only further down do you mention your car is standard powered, so I'm suggesting you stick with standard plugs. My car runs totally fine tuned to 275bhp on a stage1 Map using standard plugs, so they must be good for standard power.
  15. AudiLondon
    AudiLondon Member
    95
    Aaaah i get ya now.. Alrite so standard plugs but as mentioned above BKR7E as a pose to 6E?
  16. AudiLondon
    AudiLondon Member
    95
    After checking for compatibility both the BKR6E and the BKR7E are coming up as incompatible for the Audi S3 :wtf:
    Went on the NGK website and the recommended spark plugs are the PFR6Q Which are these: Audi A3 NGK Platinum Spark Plugs 1.8 Turbo PFR6Q x 4 | eBay
    Obviously I don't want to waste money on the wrong equipment. Any further help would be appreciated.
  17. JimS3
    JimS3 Active Member
    736
    72
    These are the ones you want:
    NGK SPARK PLUGS / NGK SPARKPLUGS - BKR6E - 6962 NGK Spark Plugs & Denso Sparkplugs NGK SPARK PLUGS - BKR
    BKR6E -6962
  18. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    I used super 4s and had one fail on me, the electrode worked loose and caused a mis-fire, I was very lucky. I swapped to ngk's with heat rating of 6 and all has been sweet since.
  19. AudiLondon
    AudiLondon Member
    95
  20. Stuart B
    Stuart B Well-Known Member
    1,925
    351
    Hi, I know this is an old thread, but I am looking to change the spark plugs from the Super 4 Bosch I fitted when I got my 2001 S3 to NGK.
    The spark plug recommended on this thread NGK BKR6E 6962 they are about £2 each rather than the £12 each for the recommended NGK PFR6Q.
    Can anyone confirm the cheaper NGK's are actually better than the Audi specified?
  21. jojo
    28,997
    3,649
    The factory recommended plugs are platinum tipped, and are suppose to be changed every 40k miles! Obviously, with a tuned motor, you want to change the frequency of sparkplug changes. The cheaper option, I would recommend swop them every 6k miles if the car is stage1 or above state of tune. For me personally, I just use the platinum ones and swop them every 20k miles instead of 40k.
  22. Stuart B
    1,925
    351
    thanks for the clarification, I will be happy to change the plugs yearly, and re-gap the cheaper copper version to 0.7
