  1. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,483
    At last a 3 door! And best colour too! Exactly what I'd have chosen.
    Kempysue likes this.
  2. PilotAudi
    PilotAudi New Member
    2,352
    479
    We can see the split level bit of the motorway a couple of miles away so assume you did ;-) glad you are liking the car.
  3. kenny_boon
    kenny_boon Active Member
    466
    71
    Glad your enjoying :) picked up mine then 300 mike trip home. Cruise on for most and 36mpg on trip
  4. MatthewC
    MatthewC Member
    31
    14
    Hoping someone can help me here...
    When i pull up at the end of my journey, put the brake in, put the gearbox in to park, the car shuts off (auto start/stop)
    which is fine, and what i'd expect.
    But i have the advanced key, and so now i have to start the engine again with the button, to turn it off again to get out of the car.
    If i get out of the car without starting and turning off again, the car things it's still 'on' - i.e. the MMI stays up / lights on etc... but obviously, the engine never starts again from the start/stop because i've put it into park.
    It justs seems to me it can't be right that i'd have to start the engine again, to ultimately turn it off again.
    Am i doing something or missing something silly here?
    Thanks, Matt
  5. Longy
    Longy Active Member
    280
    92
    I would say you need to turn off the car via the start/stop button before the auto stop/start kicks in. From memory of the test drive vehicles, every time I pulled back into the dealership, I was always able to put the car in park or neutral (test drove both manual and s-tronic) pull up the electronic hand brake and push the start/stop button, never once did the auto stop/start turned off the engine, and yes, that feature was on as it did shut down the engine at red lights, it really felt strange when engine shuts down in a manual.
  6. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    5,408
    1,509
    I am sure you don't have to actually restart the engine but just press the start button without pushing the clutch down...
  7. MatthewC
    MatthewC Member
    31
    14
    You're right, thanks for your help, thought it'd be me just doing something stupid. I'd kept the brake pedal depressed, and so obviously it was re-starting the engine.
  8. Battlekrapz
    Battlekrapz Active Member
    418
    241
    43
    Or better, do as 99% of S3 owners do, disable this horrible PoC.
    warren_S5 likes this.
  9. royalsteve68
    royalsteve68 Active Member
    984
    224
    43
    Reading?
  10. Itguy
    Itguy Well-Known Member
    1,130
    449
    Horseshoe pass and evo triangle completed so far today. Just had a pasty in ponderosa.
    More to come later...
  11. S3 TRS
    S3 TRS Active Member
    496
    226
    43
    What do these little symbols mean in the bottom right. They eventually change to the outside temp. [​IMG]
  12. RobH_S3
    RobH_S3 Active Member
    440
    206
    43
    I've always wondered that aswell.
  13. Battlekrapz
    418
    241
    43
    It shows if your passengers are wearing their seatbelt or not … it turns white if the passenger is wearing his seatbelt. The pictograms represent your other 3 seats in your car.
    edit: I'm unsure if the 3 seats are the back ones only or the passenger one and the two at the back. I suspect it's your backseats being represented.
  14. S3 TRS
    496
    226
    43
    Yes it's the back seats only. Middle seatbelt is clicked in. So the middle person has changed to someone sitting in the seat.
    Also just noticed I took the pics exactly 1 hour apart! Just went down on the A1 for a quick spin to new ton aycliffe and back to Sunderland. Mpg is good too.
    Battlekrapz likes this.
  15. geefunk1978
    geefunk1978 Well-Known Member
    660
    408
    Ryan_R, gilesf, MorkC68 and 3 others like this.
  16. Ashmcblue
    Ashmcblue Active Member
    208
    51
    What happens on start up? I've seen the S8 dials that rotate round to the redline and top of the speedo.
    I don't remember when I started it up on the test drive.
  17. royalsteve68
    984
    224
    43
    anyone figured out how to permanently disable start stop - I can do it manually but the instruction manual is no help
  18. PilotAudi
    2,352
    479
    Needle sweep on S3 too!
    kenny_boon likes this.
  19. Ashmcblue
    208
    51
    It's the little things isn't it!
    I can't wait for this and mostly to mash the loud pedal into the floor after I take delivery : )
    Incidentally if anyone is able to show us some footage of that whole scenario I imagine it would be much appreciated here.
    titleist007 likes this.
  20. Gazzz
    Gazzz Member
    173
    Somebody mentioned you can do it with VCDS, but otherwise there's no way :-(
  21. NotquiteWelsh
    NotquiteWelsh Active Member Audi S3
    231
    160
    43
    My S3 has been to the Ponderosa several times; I have a sausage roll there. Do also like the road from LLanberis to Capel Curig, been along there several times when they were filming, last was the Evoque. Do enjoy the car but watch out for the camera vans especially if you go through Flintshire.
    Itguy likes this.
  22. Itguy
    1,130
    449
    LLanberis to Capel Curig to done yesterday too, but the other way around.
    I'm going to do a write up as I've got some reasonable pics etc too
  23. Snake Pliskin
    Snake Pliskin Well-Known Member Supporter Team Floret Silver Audi RS3
    2,831
    3,548
    Agreed ........ that colour combination looks superb !
  24. Longy
    Longy Active Member
    280
    92
    Very nice, are they Audi rims, if so what is that pattern?
  25. geefunk1978
    660
    408
    Loving the all black!
    Somebody else been different like me too with the 10 spoke titaniums! What do you think of them? They're actually growing on me now.
  26. SAMurray
    SAMurray Member
    49
    22
    well my car is ready to pick up from this Thursday but i cant get time off work and there are no free delivery slots on Saturday!
    They are trying to sort something out to squeeze me in at some point really dont want to have to wait till next weekend.
  27. PilotAudi
    2,352
    479
    Go NOW!!! If you're blogging who's going to miss you eh ;-0
  28. Pulp84
    Pulp84 Well-Known Member Audi S3
    2,235
    1,134
    Quick question for the guys who now have their S3's....
    Has most peoples experience been that your car has been built / delivered earlier than quoted etc?
    I've been quoted week 16 (mid April) for a build and then delivered mid May time. But looking at a few posts etc seems people have been getting them circa 4 weeks early.
    Wishful thinking lol?
  29. Sparks43
    Sparks43 3rd Gear
    138
    27
    Ordered mine last week of September and was told build week 9 end of March delivery came into build week 5 arrived 2 weeks ago and I picked up Saturday the 1st so about right I reckon
    Not wishful thinking hopefully
  30. S3 TRS
    496
    226
    43
    Mine should be built in 2 weeks. Quoted delivery in mid April so 6 weeks time but expecting build to be locked this week or early next week.
  31. Kempysue
    Kempysue Active Member
    115
    76
    I really like them. Wasn't sure when I ordered but very pleased I went with the upgrade now I've seen them with the black on black colour combo :)
    geefunk1978 likes this.
  32. ConS3
    ConS3 Active Member
    409
    156
    43
    Love that all black trim.
    Is the trim around the windows more glossy or matte in colour?
  33. SAMurray
    SAMurray Member
    49
    22
    picking it up on sunday :D
    Gives me plenty of time to clear out the garage on saturday and make room for it!
  34. RobH_S3
    440
    206
    43
    I think I prefer the titanium's more than the star design now, wish id specced them tbh.
  35. geefunk1978
    660
    408
    Wanna swap?!
  36. Kempysue
    115
    76
    They're glossy black. Very nice indeed. Can defo recommend esp if you're after for that stealth look! ;-)
  37. PilotAudi
    2,352
    479
    I'm pleased with the standard S3 star design on the Sportback and they actually look darker than in the brochure which is good on a Phantom Black car.
    Kempysue and rams_s3 like this.
  38. CraigI
    CraigI Well-Known Member
    1,477
    1,211
    Standard S3 wheels are perfect for the car in Sportback mode IMO.
    I've changed standard wheels a number of times on a number of cars and don't think the S3 needs it at all.
  39. SAMurray
    SAMurray Member
    49
    22
    When I first started looking at S3's seeing the images online made me sure I was going to pcik something other than the standard wheels. Changed my mind when I saw them in person really works on the Sportback and with Misano Red :)
  40. Aran383
    Aran383 Active Member
    106
    89
    Few pics after it's first detail with the newly sprayed wheels.
    screenbubble, Adam., vakaviti and 4 others like this.
