2013 A4 Black Edition front fog grill removal
Anthony566 Jan 18, 2014
  1. Anthony566
    Anthony566 Active Member
    732
    111
    43
    Has anyone done this as they are not the same as the B8 instructions I have found ......
  2. Audi.Quattro
    Audi.Quattro Active Member
    234
    yep, there's a small hole near number plate that you need to insert a tool into. I got an old screwdriver @4mm thick and @8" long, I then bent the end inch over 90deg.
    You can then hook this into the hole and the screwdriver handle should give you sufficient grip to pull the grill off. it takes a serious pull to do so, but just go for it.
  3. Anthony566
    732
    111
    43
    And is this the best way to cchange the fog light bulbs ??
  4. Audi.Quattro
    234
    Either that or take out the wheel arch liner, it's your choice but if your car has as much mud on it as mine, my idea is the cleanest. Finding or making a tool takes longer than changing the bulbs.
  5. JG51 AUD
    JG51 AUD Well-Known Member Team Glacier TFSI Owners Group Team V6 Gold Supporter Audi S5 quattro Black Edition Supercharged
    2,656
    1,542
    Easy way to do this is, remove two screws from inner wheel arch liner, fold liner inward and you'll see fog light housing, just change from there. 10 minute job, simples. :thumbsup:
    ps. Remember to have your wheel facing inward for easy access.
  6. Daggerit
    Daggerit Well-Known Member Team Floret Silver TFSI Owners Group Team V6 Audi S4 quattro Audi Avant Owner Group
    1,949
    713
    I have a tool in the boot of my car that came with it, circle with a little hook on it? That's what I used to pull the front grill out, then two screws and you're sorted! :)
  7. Parklife
    Parklife Active Member
    122
    30
    Definitely easier going in through the wheel arch! All you need to do is unscrew 2 screws and pull it back slightly, bulb then twists out.
  8. Audi.Quattro
    234
    I looked and i have the tool in boot too, the bent screwdiver worked though.
    Daggerit likes this.
  9. Zafi
    Zafi Well-Known Member
    1,299
    327
    That tool in the boot is for pulling the wheel centre caps off.
  10. Anthony566
    732
    111
    43
    I have decided I'm not pulling the front grills off I am just going in through the wheel arch ... I will post some photos once it's done to show how I did it.
  11. Cyprio
    Cyprio Active Member
    125
    34
    Great stuff!
    Which bulbs did you buy in the end?
  12. Anthony566
    732
    111
    43
    I got a set from t8ups and I have fitted them now ... very easy to fit through the wheel arch and they are white with a hint of blue. I have before and after photo's I will put them as soon as I can.
  13. Cyprio
    125
    34
    Great! :thumbsup:
  14. Anthony566
    732
    111
    43
    So I have replaced the Std Audi Bulbs with a set from t8ups and this is what they look like :-
    Before
    After
    They do look much better and this has put my OCD to bed as every time I walk up to the car in the car park and those yellow lights came on it just drove me mad !!!!
    These bulbs are direct replacement ones and are just plug and play. ( These are not LED Bulbs )
  15. Point_Audi
    Point_Audi Vorsprung durch Technik Staff Member Moderator VCDS Map User Gold Supporter Team Tornado Audi A5 Black Edition S-line owners group
    1,393
    977
    Very nice Anthony, I had the same OCD with the colour and Trups was able to help also! :) lol
  16. Cyprio
    125
    34
    So much better! No errors I take it?
  17. Anthony566
    732
    111
    43
    No errors at all and its just 3 screws out of the wheel arch liner and your in ....
    Cyprio likes this.
  18. Liquidfusion-S3
    Liquidfusion-S3 I fall to peer pressure!
    1,475
    726
    What exact bulbs are these? Are they from a member here? Looking to do the same as yours, just noticed the nasty yellows on mine too! :(
  19. Anthony566
    732
    111
    43
    Yes just look for T8ups he is a forum member
    t8ups likes this.
  20. allanmb
    allanmb Well-Known Member Team Tango Audi S3 quattro
    735
    533
    93
    This looks like a great mod. Roughly how much were the bulbs, and how long did they take to fit?
  21. Anthony566
    732
    111
    43
    Half an hour to fit and less than £15 posted
  22. allanmb
    735
    533
    93
    Great, I am already talking to T8ups about internal LED lights so might just add this to the list :)
  23. Liquidfusion-S3
    1,475
    726
    I was a bit worried as half the metal base popped off the holder, I pushed it back in and still worked thankfully.
    Took me about 30 minutes too.
    You can't really see it but my xenon headlights have a tint of blue not seen in the picture, and t8ups fog lights are whiter than this picture.
    These are with his fog lights (H8)
  24. Spares
    Spares Member
    87
    The fog light bulbs are yellow for a reason, white light reflects off fog but yellow penetrates it, your rendering your fog lights useless by changing the bulbs to white.
    AshA4 likes this.
  25. Anthony566
    732
    111
    43
    The schedules to the regs give any specifications that are required for both obligatory lamps and for "recognised" optional lamps such as front fog lights in terms of things like number, positioning and colour.* For front fogs (schedule 6) the colour is specified as being white or yellow:*
  26. Spares
    Spares Member
    87
    That's as maybe, just saying white light is hopeless in fog, it just reflects straight back at you, changing the bulbs to give a bright white light means you might as well not have em fitted at all, cos when you need em they'll be as much use as a chocolate tea pot. More of a hinderance than a help.
  27. Anthony566
    732
    111
    43
    I have had white bulbs in an A4 for almost ten years and they have worked just fine ... these are not the crazzy 100 watt ones they are almost the same brightness as the ones I removed so work just fine ... I have used them in fog a few times since fitting and they were just fine ....
  28. Daggerit
    1,949
    713
    Have to admit that I've never noticed a difference when I put on the fog lights to be honest and that's with the standard units... Maybe just me!
  29. Audi.Quattro
    234
    I agree, the B8.5 Fogs are not a lot of cop, regardless of bulbs
  30. allanmb
    735
    533
    93
    Interior LEDs and white fogs all fitted and looking much better :)
  31. Daggerit
    1,949
    713
    Yeah, popped in a could of trups white fogs, look much better!
    About two minutes per light, really handy Audi giving you all the tools you need in the boot! Haha.
  32. lukus89
    lukus89 Active Member VCDS Map User
    178
    32
    Hey,
    I''ve got this same car and bulbs, but can someone suggest a good tool to pull out the fog cover?
    thanks
  33. Anthony566
    732
    111
    43
    Don't pull the front cover off .... just take the three screws out of the wheel arch cover it's really easy to do.
  34. Bristle Hound
    Bristle Hound Moderator Staff Member Moderator Audi S4 Supercharged
    8,584
    11,212
  35. lukus89
    178
    32
    Cheers pal
  36. lukus89
    178
    32
    Btw going from the back is much harder, on mine at least.
  37. Audi.Quattro
    234
    covers come of easy with the right tool. VW's have a tool that pulls off wheel bolt caps, they have a hole on the middle of them.. The same tool is also used to pull off the fog surrounds. Its a essentally a thick wire letter "P" with a hook on the end, loads on fleabay
  38. lukus89
    178
    32
    Any idea on the name ? I'll buy one if I can find it.
  39. Audi.Quattro
    234
    VW wheel nut cap removal tool.
    Also when using, make sure its not too cold, be brave and one strong yank/pull will do it.
  40. lukus89
    178
    32
    Legend thank you. For 2.99 I ain't gonna mess about looking to save a few pence.
    Thanks again
