2013 A4 Avant "Clunk" braking in reverse!!
A3BE Nov 24, 2013
  1. A3BE
    A3BE Member
    69
    My 2013 A4 Avant Black Edition has a very noticeable "clonk" when the brakes are pressed when moving in reverse, has anyone identified the cause or had the same issue on their B8.5 model? I have spoken to my Audi Dealer and they said it was a "characteristic" of the brake pads moving in the calliper which I do not accept as the clonk is quite severe and has only appeared during the past 2,000 miles (car has covered 5,000)
    Any pointers to the cause greatly appreciated.
    Dave
  2. Broken Byzan
    13,244
    468
    pads moving would be correct, but usually on worn high milage cars.
    DO NOT accept it as a characteristic, perhaps find another dealer?
    A3BE likes this.
  3. Daggerit
    Daggerit Well-Known Member Team Floret Silver TFSI Owners Group Team V6 Audi S4 quattro Audi Avant Owner Group
    1,963
    722
    I definitely don't have this issue...
    A3BE likes this.
  4. A3BE
    A3BE Member
    69
    Cheers for the replies guy's.......the clonk noise referred to is quite severe when reversing and applying the brakes the sudden clonk noise sounds like I have hit a bollard!
    I am due to attend a meeting over at my Audi dealer today to discuss this issue further......but as usual with these "characteristic" defects the "computer will say no"!!
  5. NHN
    29,596
    1,782
    Fitting some pad shims fixes this on the 345mm found on MK5 R32, S3 & 3.2 8P chassis, done this myself, but as above it should be addressed by audi on such a new car.
    A3BE likes this.
  6. Gillm
    Gillm Member
    110
    I would look at the front subframe tbh my mk5 golf did this and was fixed by changing shims
  7. A3BE
    A3BE Member
    69
    Attended Audi, accompanied so called master technician on road test and no "Clunk".....typical:banghead:.........Technician confirmed nothing they could do unless the noise can be reproduced:wtf:.......a simple request for the dealership head of business soon alters their stance with my car booked in for further investigation next week
  8. A3BE
    A3BE Member
    69
    Well my A4 Black Edition is with Audi ATM and so far they have changed the front brake pads in their attempt to resolve the "clunk" when braking in reverse.
    My A4 is also blighted with a very notchy 1st - 2nd gear change, Audi have changed the gearbox oil to an unconfirmed spec and want to change the clutch and flywheel which is concerning on a car that has covered only 6000 miles. I'm in a loaner ATM so until my A4 is returned I will reserve judgement on whether Audi's attempt to cure the aforementioned problems has been a success!
  9. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Funny this thread should pop up as my A3 has started doing this recently too. Front pads changed 3 weeks ago.
    Will get it looked at.
  10. A3BE
    A3BE Member
    69
    Well got my A4 Avant BE back from Audi after a week in their workshop......"clunk" whilst braking in reverse was identified as coming from front brake pads. My A4 had also inherited the poor and notchy 1st and 2nd gear change coupled with a judder at the top end of the clutch pedal. The gearbox was removed and confirmed "hotspots" on the flywheel, subsequently a complete new clutch assembly and flywheel was fitted. Additionally the gearbox oil was replaced with a thinner viscosity oil, all the aforementioned covered under manufacturers warranty.
    Pleased to confirm that the gear change has a marked improvement over pre oil change, clutch operation is smoother and the "clunk" has been eliminated.....now to get on with enjoying the car😀
    SI-W85 likes this.
  11. johnnythepie
    johnnythepie Well-Known Member
    2,243
    76
    Good for you mate.In my case the clutch judder would never happen when at the dealers. Understandable that they wont act unless they can have it demonstrated.As I work in a VAG dealers now, i understand the frustration of the customer, but believe me the amount of people booking an appointment for something that is not apparant is massive.My poor gear selection was also sorted after a change of oil.All this on a new car (albeit four years ago).
  12. A3BE
    A3BE Member
    69
    Johnnythepie I can well believe what you are saying re the amount of customers reporting faults that do not exsist or cannot be replicated at the dealers. Fortunately for myself I am qualified and have worked in the trade for 25+ years so can accurately describe and relate to the issues that afflicted my A4.
    Half the battle for the technician is to obtain a good description of any issue that requires further investigation. My experience and knowledge also realise that unlike many customers I never get fobbed off by technical excuses or "characteristics" often blamed by many dealers for the problems on new cars. I have to admit that the clutch judder was quite slight on my A4 and only apparent when the clutch was hot after driving in stop start traffic, as such i did not think it would warrant a replacement, however Audi tech thought it necessary to pull the gearbox out and my suspicions proved right as there were hotspots found on the flywheel and a replacement was authorised. Likewise the clunking whilst breaking in reverse, my wife took my A4 into Audi on my behalf and was fobbed off by a master tech who confirmed that the clunk is apparent on all A4's and is a characteristic of the brake pads moving!!..... That was until I took the car in and it was eventually accepted as a defect and corrected under warranty.
  13. a43.0v6tdi
    a43.0v6tdi Dave
    37
    Hi mate
    Did the garage just change the pads to get rid of the clunk? Have same issue when reversing, I changed pads myself about 7 months ago used apex, have since heard negative feedback about them, any thoughts on pads or stick oem?
  14. dieselguy
    dieselguy Active Member
    204
    25
    Glad you got things sorted. In my experience you have to persist until they investigate further, as they are likely to try to get rid of you otherwise (especially under warranty).
    A3BE likes this.
  15. A3BE
    A3BE Member
    69
    The pads were replaced and a unspecified copper anti seize applied.....Audi did not go into too much detail. The "clunk" has been cured to date so fingers crossed it will stop that way, although I have heard of many other issues that can cause the "clunk" in particular sway bar links!
