2011. A6 tdi s-line se 170cr Engine code?
rajsta Mar 14, 2014
  1. rajsta
    rajsta Member
    49
    Can someone confirm this is correct as when I search online I can find next to nothing!In the book it states my engine is "CAHA".
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,723
    649
    "CAHA" is a 2.0TDi engine, what are you looking for, you will fine that newer engines won't show up much in google as they will still be under warranty and fixed by dealers, once they are around 5+ years old more people will be asking for support.
  3. rajsta
    rajsta Member
    49
    Ah OK thanks, so I'm correct in stating my engine code is a "CAHA"?
    I don't know why, but I randomly thought vag engine codes were 3 letters long!
    My other car has probably influenced me which has an "AWX" engine code.
  4. rajsta
    rajsta Member
    49
    And I'm actually looking to see if there are any egr delete kits out there as well as dpf delete kits.
  5. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    New CR engines are normally 4 letters long. Don't delete your DPF just yet, google for the new MOT rules regarding DPF.
  6. rajsta
    rajsta Member
    49
    Ah bugger don't tell me theres other rules and regs out there now! Typical!
  7. a6_chris
    1,883
    160
    Yup, if it was meant to be there from factory and it's been removed then you'll get a nice big fail.
  8. rajsta
    rajsta Member
    49
    So I see removing a dpf on a car that is fitted with it as OE is now illegal.
    Never mind I'll knock that off the list.
    That just leaves egr delete.!??
  9. B5NUT
    3,723
    649
    Best contact some of the remap company's as they may be able to find a kit that would fit your engine, then they would need to map out the EGR.
  10. rajsta
    rajsta Member
    49
    I'll have a hunt around.
    I'm really not a fan of having used exhaust gases recirculating back into the engine.
    A definite no no for me.
  11. B5NUT
    3,723
    649
    Yer, looking for a kit for my 3.0TDi, but as I will need to get the car remap to remove the EGR, I'm looking for a local company with a good 4WD rolling road, as I may as well go for a decent remap.
  12. rajsta
    rajsta Member
    49
    Shark performance for your remap
  13. rajsta
    rajsta Member
    49
    Yes its now an not failure to remove a dpf from a vehicle fitted with one from factory.
    However, There is a local company that will remove the dpf and cut it open and remove all the rubbish and weld a straight through pipe in there before rewelding the dpf box back up.
    Surely this will get through an not as the dpf box will still visibly be there but it will now be a straight through pipe in disguise.
  14. B5NUT
    3,723
    649
