2010 S3 Black Edition with Eibach Pro's and standard 18" wheels.
Y444GAR Jun 14, 2010
  1. Y444GAR
    Y444GAR Member
    198
    Went out tonight and took pictures with my phone, hope this helps Rich!!
    Mario8P likes this.
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    looks just right mate, i may invest in some myself eventually
  3. RicoS3
    RicoS3 Sprint Blue is the new Ibis!
    622
    70
    Nice one Gary, much obliged sir! I appreciate you going and taking pics, many thanks. Think I'm sold. I'm running 19's but a lower profile tyre, so should work. Japper has done all the calculations necessary, so hopefully he'll be along presently to confirm.
    Ca r looks great by the way. Out of interest, what would you say the overall drop at the front is?
  4. v1raj
    v1raj Member
    308
    20
    Looks great. How the ride quality compared to the standard suspension?
  5. Y444GAR
    Y444GAR Member
    198
    Not a problem, would have got more pictures but my camera went dead on me.
    The ride quality is very similar to the standard set up if not exact same.
    I measured the gap between the top of the front wheel and my arch when the car was standard and the gap was 115 mm and after the springs went in the gap went down to 95mm. My car has a gap of 95mm at the rear also so was very pleased with the drop. I had heard stories about the Pro springs not lowering the car by the full 20mm as stated on the box but with my measurements eibach were spot on.
  6. Richy_C
    Richy_C Active Member
    706
    159
    43
    Looks really good.
    i have a A3 black SB on order, is that the same height standard as the S3? wondering if i would have the same result.
  7. Japper
    Japper Ibis S3 Fan Club
    1,495
    Looks great.
    Could you possibly measure from ground to arch centre lip for both front and rear on flat ground?.
  8. akash_sky1
    akash_sky1 Active Member
    1,181
    The S3 BE with the Rs4 style wheels look v similar to the A3 BE. Nice drop there.
  9. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    looks much better mate :o.k:
  10. deano670
    deano670 Too Much Hype
    270
    looks sweet
  11. RicoS3
    622
    70
    Gary, just a couple more measurements please? Could you possibly measure from ground to arch centre lip for both front and rear on flat ground? What height is the front splitter now sitting at?
    Sorry about this, just need to be certain as I've burnt too much money buying springs fitting them and then taking them out again!! Help is well appreciated bro!
  12. PH1L
    PH1L Gievf Buckets
    3,851
    40
    your s3 would look so much better with black mirror covers, swap? :p
  13. Y444GAR
    Y444GAR Member
    198
    I will get that measurements for you guys.
    No thanks mate would rather have the ones I've got.
  14. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i was only messing anyway i have absolutly no idea on how my car will look finished really thrown off on the build i do know if i plan to keep it for long enough, youve sold me on the ebaichs so thanks, that being said whats the deal with driving over roadkill, are you still high enough so it is not a problem?
  15. Jamiekip
    Jamiekip Member
    717
    Off with their heads ;)
  16. Y444GAR
    Y444GAR Member
    198
    Hope this helps guys, the measurements were taken when my car was in my garage so perfectly flat ground. Just used the photo to show exactly where they were taken from. The front bumper was measured from the furthest sticking out point of the car.
    One thing I must point out, I adjusted my lights up a touch using the allen key adjustments next to the lights after fitting the springs because the lights were pointing down slightly.
    Wheels are 225/40/18 with nearly new rubber.
  17. RicoS3
    622
    70
    Gary, you're a geezer! Many thanks mate, just as requested. Really appreciate all the effort. :o.k:
    I'll keep you updated, but this looks the way to go. Japper, what do you think?
    Cracking car mate!
  18. Japper
    1,495
    Thanks Y444GAR.
    Rich, this equates to a 16-17mm drop which is perfect. With an approx. ( depending where the exact measurement was taken to ) 20mm drop at splitter. This will give a 5 1/2" 'clearance' below the splitter at lowest point.
    Maybe we could get a group buy and fit from Lovett............lol.
  19. Shane.
    Shane. Member
    486
    Do you suffer any problems with rubbing on the arches or speed bumps? And are the springs very visible (being bright red is putting me off the eibachs and more towards H&R)
    Shane
  20. RicoS3
    622
    70
    You're the engineer Carl mate, so I trust you! I am really tempted to go for these right away, just don't fancy regretting it again. I'll do a few measurements here and get in touch with you tomorrow.
    Thanks again Gary, top work.
  21. Y444GAR
    Y444GAR Member
    198
    The springs are a really dark grey, more or less black. Not red. No scuffing with 5 people in the car driving fast over bumpy roads around my area. North east scotland, roads are terrible.
    Gary.
  22. Y444GAR
    Y444GAR Member
    198
    Shane be aware these springs are for an S3, Front springs only.
  23. Shane.
    Shane. Member
    486
    Ah right, I been looking at the Eibach and H&R springs for mine but not sure what drop to go for I am running the 18" RS6 style alloys and am looking to just get it sitting right as the arch gaps seem abit big for my liking. I have just read on a thread that the S Line/Sport suspension is lowered 25mm from factory so I'd need an additional 25/35mm on top of that (so basically 50-55mm springs) I think
  24. Bazzle
    Bazzle Active Member
    509
    98
    Ive just orderd the Eibach Pro. for my 2010 S3
    E10-15-007-14-20
    They are just a pair of lowered front (20mm) and use the oem rears as a matched set.
