2010 Facelift front Conversion, Xenons Displaying Warning on Dash but no faults in 09
Usual Suspect Mar 22, 2013
  1. Usual Suspect
    Usual Suspect New Member
    Hi everyone
    Got a little issue with the headlights on an Audi A3 2005 55 plate. Its had a facelift 2010 front fitted alongside the Bi xenon drl headlights.
    I have fitted the kufatec wiring harness and plugged the wires in the relevant places in the Central Electronics. Everything works as it should and i get no faults in the module.
    I have coded the Xenons in using VCDS and re checked the fault memory of the Central Electronics and I get no faults.
    The Xenons shutters, drls indicators etc all work correclty.
    Problem i have is the dash displays the bulb warning out symbol and flashes the following on ignition:
    Bulb for Main beam left &
    Bulb for main beam Right.
    Anyone know why this maybe?
    I have attached a scan below.
    Many thanks for your time.
    VCDS Version: Beta 12.10.3
    Data version: 20130228
    Thursday,21,March,2013,23:13:02:54447
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 7D
    VIN: WAUZZZ8P86B010885 Mileage: 171290km/106434miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 DT HW: 028 101 189 2
    Component: R4 2,0L EDC 0000AG 7000
    Revision: 12345678 Serial number: AUX7Z0E9FNO0QH
    Coding: 0000078
    Shop #: WSC 00046 412 106496
    VCID: 78F42FDB0B07E4DEB75
    1 Fault Found:
    18080 - Coolant Fan Control 1
    P1672 - 000 - Open or Short to Ground
    Freeze Frame:
    RPM: 0 /min
    Torque: 20.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.31 V
    Bin. Bits: 00000100
    Temperature: 55.8°C
    Duty Cycle: 9.6 %
    Readiness: 0 0 1 1 1
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 042 S HW: 02E 927 770 AE
    Component: GSG DSG 070 1102
    Revision: 04507000 Serial number: 00000510130338
    Coding: 0000020
    Shop #: WSC 00046 412 491520
    VCID: 234E28B7E2015706B27
    No fault code found.
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
    Component: ESP FRONT MK60 0102
    Revision: 00H13001
    Coding: 0023170
    VCID: 71E212FF687DB59670B
    1 Fault Found:
    00493 - ESP-Sensor Unit (G419)
    014 - Defective
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
    Component: KlimavollautomatH09 0100
    Revision: 000086 Serial number: 8P0820043BH
    Shop #: WSC 00000 000 00000
    VCID: 73EE18F712618786827
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H36 1201
    Revision: 00H36000 Serial number: 00000002263167
    Coding: 0B8A4B07A214100000000000000000000008FE175C0600
    Shop #: WSC 00046 123 106496
    VCID: 4084873B13576C1ECF5
    Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 00046
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
    Component: Airbag 9.41 H11 3520
    Revision: 91H1135 Serial number: 0037W000ZR8Q
    Coding: 0071612
    VCID: 47969C2736795B260EF
    Subsystem 1 - Serial number: 63328RB400BBE9A1Y
    Subsystem 2 - Serial number: 63428RB400BBF536U
    Subsystem 3 - Serial number: 63528RB400BBD742S
    Subsystem 4 - Serial number: 63628RB400BBD733T
    Subsystem 5 - Serial number: 63700RB4048AB6E8X
    Subsystem 6 - Serial number: 63800RB4048AB6D3S
    2 Faults Found:
    01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
    008 - Implausible Signal - MIL ON
    Freeze Frame:
    Fault Status: 11101000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 197
    Mileage: 171298 km
    Time Indication: 0
    Date: 2013.03.21
    Time: 23:09:41
    01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 197
    Mileage: 171298 km
    Time Indication: 0
    Date: 2013.03.21
    Time: 23:09:41
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H34 0070
    Coding: 0012112
    Shop #: WSC 00046 412 12345
    VCID: 4182823F185D6516C0B
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 H06 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 B HW: 8P0 920 981 B
    Component: KOMBIINSTR. VDO H80 0420
    Revision: D06 Serial number: 2249ED06006304
    Coding: 0000403
    Shop #: WSC 00045 067 57207
    VCID: 3776ECE746992BA67EF
    Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 G HW: 1K0 907 951
    Component: J533__Gateway H10 0140
    Revision: H10 Serial number: 30001059268F31
    Coding: 3F0F0B4A07000101
    Shop #: WSC 00046 412 187596
    VCID: 2B5EC0978AD19F460A7
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D06 Serial number: AUX7Z0E9FNO0QH
    Shop #: WSC 00045 210 83908
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
    Component: RNS-E PU EU H06 0200
    Revision: 0000012S Serial number: AUZBZ7LD207020
    Coding: 0215755
    Shop #: WSC 00355 211 85016
    VCID: 346CDBEB57EFC0BE5BD
    2 Faults Found:
    00856 - Radio Antenna
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 197
    Mileage: 171298 km
    Time Indication: 0
    Date: 2013.03.21
    Time: 23:10:02
    Freeze Frame:
    Mileage: 171290 km
    Count: 2103
    Clock: 23:09
    00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 197
    Mileage: 171298 km
    Time Indication: 0
    Date: 2013.03.21
    Time: 23:09:59
    Freeze Frame:
    Mileage: 171290 km
    Count: 2103
    Clock: 23:09
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
    Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
    Component: Tuer-SG H03 0060
    Coding: 0004660
    Shop #: WSC 06314 000 00000
    VCID: 42808D331D5B7E0ED91
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 K
    Component: EPS_ZFLS Kl.5 D06 1701
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H03 0040
    Coding: 198000186D288505489AC63300
    VCID: F9F2AADFB00D7DD648B
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH27 0160
    Revision: 00005 Serial number: 30659525652907
    VCID: F0E497FBE3773C9EFF5
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
    Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
    Coding: 0004660
    VCID: 438E883702417706D27
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0215755
    2 Faults Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 197
    Mileage: 171298 km
    Time Indication: 0
    Date: 2013.03.21
    Time: 23:10:02
    Freeze Frame:
    Mileage: 171290 km
    Count: 2103
    Clock: 23:09
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 197
    Mileage: 171298 km
    Time Indication: 0
    Date: 2013.03.21
    Time: 23:09:59
    Freeze Frame:
    Mileage: 171290 km
    Count: 2103
    Clock: 23:09
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    VCID: 2D5ACE8FB4C59176143
    End ---------------------------------------------------------------------
  2. TDIA3
    TDIA3 New Member
    Coding: 00062736
    Shop #: WSC 00046
    F module does not support 8P3 headlights without errors, you need either a K or a P module.
  3. Usual Suspect
    Thanks mate.
    Apart from this and coding the module is this all I need?
    Do these modules have component protection enabled or can I replace it without any visits to the dealer.
    Many thanks
  4. TDIA3
    TDIA3 New Member
    Short answer is yes, you can either copy and paste code, but the best way is to use the long code helper and copy the bits ticked on every byte on your old unit and apply these to the new unit. No component protection on them so no dealer visit required if done correctly.
  5. Usual Suspect
    Thats great.
    Thank you very much.
  6. Ash187
    7,490
    742
    not true!
    i have an F module in my car as do a couple other guys that i have assisted with the facelift. the F module works with the LED DRL headlights
