2008 A4 2.7TDI Avant, Engine warning lite... is it safe to drive and any advice on potential cause?
MARKEC
Hi Guys,
I have a 2008 A4 2.7TDI V6. The Engine warning lite has just come on...
I had a new EGR valve fitted about 3000 miles ago and all has been fine till now. I have notices a couple of time a slight drop in power while cruising along otherwise it seems fine, but now I think of it, it does seem sluggish on the take off. Also I have noticed a lot of water running off from the air con run off under the car (understandably it will put out more while the weather is hot due to extended use of the air con).
Any Ideas folks because appart from the EGR I'm at a slight loss
