s3_stu_260
hi guys
any advice on what might be wrong with my car would be much appreciated
to start at the beginning
car = 2008 "58" audi a4 2.0 tdi cab engine code BPW less than 50k miles
faults :-
1, DPF light on dash, loss of power ( dpf removed and software adapted to allow for this)
2, misfire ( there has been no good period between dpf issue and misfire)
work done so far :-
1, diagnostics with vag.com ( no fault codes )
2, all 4 injectors removed and tested by specialist with no faults found ( replaced with new seals )
3, live data showed no.4 injector to be considerably different to other 3
4, injectors swapped no.1 & no.4, problem still at no.4
5, wiring loom for injectors replaced
6, compression test showed all equal and good
7, egr valve removed and checked ( all working when compared to a new one )
the injectors have been installed and set as per autodata
please if i have missed something or you have any thoughts on the matter as its doing my head in
faults :-
work done so far :-
