Ok got a slight wobble on idle. Doesn't do this from cold but it becomes apparent when warm 90 as indicated on temp gauge.
So far I have checked for fault codes but there aern't any.
Flywheel and clutch only just done so it ain't that.
Went to Audi and they suggested I get the injectors cleaned by them which has now been done and a new injector loom fitted but still the wobble persists.
Injectors show a 5% tolerance difference and there are no misfires. In fact it drives perfectly well except that when first taking off when cold there is a slight splutter which doesn't manifest itself again.
Just wondering where next to look for the fault. Engine mounts look ok with no leaks.
Audi said when watching the wobble on idele that they've seen alot worse indicating it must be a common problem. Do I live with this.....is it that common as it seems it bit pants to me.....my father's 2 litre A6 on a 57 plate doesn't do the same.
Any ideas chaps or cures??
