2007 Sprortback - cup holder
h5djr Apr 5, 2007
  1. h5djr
    9,420
    1,746
    On the latest 2007 Sportback with the new Symphony II+ radio, does anyone know if the storage tray can be changed for a cup holder.
    I've looked at the previous threads about this but they all seem to refer to earlier models with the previous version of the Symphony / Concert II
  2. normski
    normski Member
    497
    Ditto the A3/S3 - same layout...or even a really tidy aftermarket holder would do me fine.
  3. Evotek
    Evotek Member
    I tried to add that to my order but was told it was not possible with the new Concert unit.
  4. Sinny71
    Sinny71 S55 LKS
    779
    I wonder whether its because the row of switches nd storage tray is slightly narrower with the double din HU's. As its located slightly lower and the centre console tapers in, maybe they have cut the width from the storage tray.
    Maybe I'm barking up the wrong tree but perhaps its posible to mod a cupholder to fit if its just a case of shaving a few mm from the back of it.???
    Someone needs to borrow one from a single din car and just see why it wont fit. :icon_thumright:
  5. mcmasman
    mcmasman Member
    152
    Been told the same. Does anyone know if it is possible to retro fit a cup holder using the not-so-useful card holder tray?
  6. jo_sal77
    jo_sal77 No Comment!
    29
    Hello! Yes I can say that I have managed to successfully do this small transplant operation! :)
    Yes the storage tray is narrower and angled differently. But don't let this fool you!
    Mearly take out the storage tray... Then you have to carefully take off the front cover of this tray. It is this front cover that you have to use for the cup holder.
    Next take off the front cover on the cupholder... Replace it with the storage tray cover, (May need filing/sanding down on the inner corners a bit) then fit back into the dash... and viola!! Blended neatly into the dash! Only snagg though is that it will still have the sign for a storage tray and not the cup sign.
  7. Sinny71
    Sinny71 S55 LKS
    779
    Just means it will look standard and very stealthy. :)
  8. biryets
    biryets New Member
    12
    Another reason why you don't get a cup holder with a double-DIN unit is because if you have a drink in the holder in the lower position, it will interfere with gear changing. i
  9. Vertigo1
    Vertigo1 Well-Known Member
    3,465
    623
    I'm not sure I'd want a cup holder below the head-unit as the slightest spill could have nasty consequences.
  10. h5djr
    9,420
    1,746
    Another advatange for an S-tronic !
    I would only ever use mine when I was parked, not whilst I was driving.
  11. jo_sal77
    29
    Snag number 2!
    Unless you have big hand nuckles yes you will hit the cup holder on a manual gear shift. Another snag is you will have difficulty changing the sat-nav views not to mention if you had a cup in the way of the screen! lol....
    I only have it now cause it looks like an impressive foldable cup deck to show off to your fellow friends! Even more usefull on them McDo trips, when you really want to avoid the chav's indoors. Going through drive-thru, I used to order a meal and then they hand you that delicate cup you decide to put in between your legs while driving. Try gear shifting then! haha.
  12. Plank
    Plank Member
    78
    Do you get out much? :D
