2007 A3 2.0 TDI 170, Clutch Switch Location?? Help
davsmith64 Feb 1, 2013
  1. davsmith64
    davsmith64 New Member
    Hello All,
    Ive just fitted Retrofitted Cruise Control Stalk & ECU to my A3.
    Coded it all in correctly, In Engine & Steering
    However it dont work :/
    In VCDS i go to Measuring Block 006 in engine. It shows my brake switch is working, however doesnt register anything on the clutch pedal.
    I cant seen to see the clutch swith and I am struggling trying to find any info regarding this.
    Can anyone help?
    Thanks Dave
  2. davsmith64
    Nobody any ideas?
    Thanks Dave
  3. NHN
    29,300
    1,702
    Clutch switch would be above the clutch pedal.
  4. davsmith64
    Ive looked above the pedal and cant see it at all. had all the under cover off to look for it.
  5. davsmith64
    Still have this issue? Does anyone know exactly where the clutch switch is?
    regards dave
  6. NHN
    29,300
    1,702
    Check the brake switch again, the clutch has a hall sender on the back end of the master cylinder, doubt its this, I would join the wires temp on brake switch as sometimes it can register as working, but not be so.
  7. davsmith64
    i will try this tomorrow. Will let you know how it goes.
