Car running fine on Friday but will not start today. Turning on the ignition the DIS shows ESP and Brake faults. No engine management light.
Called out the AA suspecting a failing battery but it's tested fine. Engine tried to turn over and almost started but sounded like I had my foot on the accelerator.
All fuses by the battery and on the drivers side tested fine. Connected a ODB2 reader and there is power on the CAN bus but no other output.
Radio, wipers, interior fans, window motors etc all work fine.
Almost sounds like a ECU failure although that would be a bit unusual.
Any ideas?
Any ideas?
