2006 avant brake disc sizes
tuffy Aug 6, 2013
  1. tuffy
    tuffy Member
    314
    13
    Hi all
    Been emailing Mtec regarding a new set of discs a pads for my 2006 2.0 TDI Avant. They are telling me there are two sizes of discs 288mm and 312mm before I remove the wheel to measure (which Mtec suggested) do anyone know which diameter is the correct one for the mentioned car?,
    Thanks.
  2. TOM.S
    TOM.S Active Member Silver Supporter
    564
    Hi.your best bet is to take wheel of and measure the discs to be honest.
    or try to give call to your local Audi dealership with your chassis number,maybe they can tell you which of the two sizes mentioned is Yours.
  3. ESD1711
    ESD1711 Active Member
    691
    219
    43
    If its the 140bhp one you have, it'll most likely be the 288mm disc. Suspect the 312 is for the Quattro or the 170 perhaps.
    You're probably best to check to be sure though cos i'm only talking from my experience of my car.
    You get a similar headache with the rears in that it could be a few sizes for those too!!
    I bught from Mtec recently too though and i'm very happy with the service and the product though, so buy with confidence :)
  4. tuffy
    tuffy Member
    314
    13
    Thanks mate.
    Mine is the 170.. So you'd say it's best to remove the wheel a measure to be sure?
  5. ESD1711
    691
    219
    43
    Yeah mate, i'd reckon so - best to make sure.
    Whap a wheel off and check. Its not necessarily the easiest thing to measure accurately while its on the car, but you should be able to tell close enough whether its 288 or 312.
    I found it easiest with the help of a mate - we held a couple of bits of welding rod across the top and bottom of the disc and measured the distance between the two rods. That way the centre of the disc doesnt get in the way :)
  6. unitzero
    unitzero Bagged B7 170 TDI Avant Audi A4 Black Edition
    568
    198
    43
    I had the same issue but measured my 170 discs whilst I had the chance when fitting my coils and they were indeed 312mm
  7. Macdoon
    Macdoon Well-Known Member Team Ibis TFSI Owners Group Gold Supporter Audi A4 S-line owners group
    2,027
    800
    170 and mine were 312 when measured
  8. gupsterg
    gupsterg Active Member
    348
    Hi,
    There should be a data sticker either in your spare wheel well or in your service log book ...
    Enter data from that here Link:- PlanetVAG.com - VW & Audi PR Code Search
    There is also a guide on that webpage about what I'm instructing you on ...
    For instance my car has a PR code of 1LG for front and 1KD for rear ...
    Next post your PR code and I'll tell you size or you go on say eurocarparts site and enter number plate and cross ref the PR code in the suggested disc's and you will have your size from the specs there ...
    Stringster likes this.
  9. tuffy
    tuffy Member
    314
    13
    Thanks a lot for that buddy.....The code its showing for the front are 1LT and 1KP for the rears
  10. gupsterg
    348
    1LT = 312mm x 25mm VAG P/N: 8E0 615 301 R
    1KP = 255mm x 12mm VAG P/N: 8E0 615 601 Q
  11. tuffy
    tuffy Member
    314
    13
    Thanks mate. Very helpful
    gupsterg likes this.
  12. Av4nt
    Av4nt Well-Known Member Team V10 Team Sprint Audi S6 quattro saloon s tronic
    1,511
    387
    Will the 170 312 front discs and calipers be ok to use on a 140 2005 a4? without having to fit anything else.
    I have 19's and the 288 looks slightly small lol....
  13. Steve220
    Steve220 Member
    234
    15
    Tuffy - i had 312mm discs on mine before the upgrade. The disc bells had vent holes in them. Running 321mm set up with allow calipers and greenstuff pads, MUCH better stopping power now :D
  14. gupsterg
    348
    288mm system have PR code 1LB , 1LE is by ATE
    312mm system have PR code 1LT , 1LF is by ATE
    So they share same tandem brake master cylinder, brake servo , regardless of engine ...
    What you will need to do is recode ABS system (module 03), look under coding here Link:- Audi Portal: ECU Diagnostic . Audi A4 8E (2001-2008) . ABS Brakes J104
