2006 A6 2.0 tdi egr fault
brian.n May 7, 2014
  1. brian.n
    brian.n Member
    34
    my car is a 2006 A6 2.0 tdi BRE engine code .
    went into limp mode last week and brought up a EML on dashboard.
    scanned it with VCDS and the following faults were logged.
    Address 01: Engine Labels: 03G-906-016-BLB.clb
    Control Module Part Number: 03G 906 016 HS HW: 028 101 255 7
    Component and/or Version: R4 2,0L EDC G000SG 9673
    Software Coding: 0000072
    Work Shop Code: WSC 00353 210 82099
    VCID: 7BF5E6813AAB6CC6CE5-802E
    3 Faults Found:
    001032 - EGR Sensor 2
    P0408 - 000 - Signal too High - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 15
    Reset counter: 255
    Mileage: 245387 km
    Time Indication: 0
    Date: 2014.04.29
    Time: 15:27:23
    Freeze Frame:
    RPM: 2268 /min
    Speed: 69.0 km/h
    Load: 38.4 %
    Lambda: -1.8 %
    Mass Air / Rev.: 705.0 mg/str
    Mass Air / Rev.: 945.0 mg/str
    Bin. Bits: 00000000
    001027 - EGR Valve (N18)
    P0403 - 000 - Malfunction
    Freeze Frame:
    Fault Status: 01110000
    Fault Priority: 2
    Fault Frequency: 178
    Reset counter: 255
    Mileage: 245407 km
    Time Indication: 0
    Date: 2014.05.01
    Time: 11:23:11
    Freeze Frame:
    RPM: 1134 /min
    Speed: 17.0 km/h
    Duty Cycle: 84.4 %
    Voltage: 13.45 V
    Mass Air / Rev.: 550.0 mg/str
    Duty Cycle: 0.0 %
    Bin. Bits: 00000000
    001025 - EGR System
    P0401 - 000 - Insufficient Flow
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 245439 km
    Time Indication: 0
    Date: 2014.05.02
    Time: 11:24:46
    Freeze Frame:
    RPM: 1806 /min
    Speed: 15.0 km/h
    Load: 17.6 %
    Duty Cycle: 14.5 %
    Duty Cycle: 94.1 %
    Mass Air / Rev.: 390.0 mg/str
    Mass Air / Rev.: 650.0 mg/str
    Readiness: 1 2 0 0 0
    so i cleared all faults and went for a drive, drove much better but still with occasional flat spots . EML did not return.
    re scanned again, this time 2 faults.
    2 Faults Found:
    001025 - EGR System
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 245567 km
    Time Indication: 0
    Date: 2014.05.06
    Time: 21:45:24
    Freeze Frame:
    RPM: 1407 /min
    Speed: 0.0 km/h
    Load: 9.8 %
    Duty Cycle: 14.5 %
    Duty Cycle: 94.1 %
    Mass Air / Rev.: 595.0 mg/str
    P0403 - 000 - Malfunction - Intermittent
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 15
    Reset counter: 255
    Mileage: 245567 km
    Time Indication: 0
    Date: 2014.05.06
    Time: 21:45:39
    Freeze Frame:
    RPM: 1407 /min
    Speed: 0.0 km/h
    Duty Cycle: 84.4 %
    Voltage: 13.30 V
    Mass Air / Rev.: 585.0 mg/str
    Duty Cycle: 0.0 %
    Bin. Bits: 00000000
    Readiness: 0 0 1 1 1
    obviously a problom with the egr valve, im going to remove and clean it tomorrow but ive read that cleaning the type on my car does,nt work and that it should just be replaced? anyone know if thisis correct?
    [FONT=Lucida Grande, Trebuchet MS, Helvetica, Arial, sans-serif]i did initially think it was the anti shudder valve/ IMF that was the problem but no fault codes have come up for it. thoughts?[/FONT]
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    4,038
    785
    I know someone who has just had to replace his EGR due to the teeth on the plastic gears had start to strip, and caused the same fault codes as your first scan. Only option was to the replace the EGR unit.
  3. brian.n
    brian.n Member
    34
    cheers for the swift reply,
    yes i have heard a similar story in that the soot build up puts stress on the drive gears and they eventually break or strip,
    also my local main dealer told me they just have to be replaced when faulty, cleaning wont cure the problom but they would say that i suppose.
  4. B5NUT
    4,038
    785
    Cleaning will prevent the teeth from stripping, but once stripped a new unit is required, as you cannot buy the gears. Best is to open up the side were the gears are and take a look. It takes very few tools to remove the EGR very much a DIY job.
    brian.n likes this.
  5. brian.n
    brian.n Member
    34
    im going to remove it at the weekend and open up the drive housing to see whats going on, ill post my findings , thanks.
  6. S3AMK20VT
    S3AMK20VT Member
    175
    12
    just get it coded/remapped out and if you want fit a blaking plate or egr delete kit
  7. brian.n
    brian.n Member
    34
    So i removed the asv and egr valves this evening. The asv looks fine, butterfly moving smoothly throughout its travel.
    Egr valve drive is damaged though.
    Stripped teeth clear to see there.
    So i guess ill have to buy a new one, darkside developments are the cheapest ive found online for a new one so far.
    As regards a egr delete kit i would do this were it not for the fact of the re map issue,
    Is it possible to do this with vcds as i have just bought the pro kit and could do it myself with a bit of guidance.
  8. B5NUT
    4,038
    785
    You would need a new ECU MAP to delete the EGR, and VCDS cannot write map files to the ECU.
