2005 A3 8P1 Headlights
Evo_Mic Apr 11, 2010
  1. Evo_Mic
    Evo_Mic Lost In The Countryside
    Been having trouble trying to get a set of HID kits to fit my 2005 A3.
    The dipped bulb keeps hitting the shield when trying to install & I don’t want to force it out the way to disturb the beam distribution. Has anyone else got round this problem?
    Or can I get a set of Xenon headlights from another car & fit them, will they just be a straight plug & play?
    Cheers,
    Mic
  2. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Mate, I would seriously do a bit of research into this.
    It has been a well documented problem that aftermarket hid's will blow your wiper motor, and it aint a cheap repair.
    Your best bet would be and try and pick up an oem pair from a A3 and fit them.
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    yup, use the search & read all the relevent issues.
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    going oem takes a lot of work but its worth it, finantially too in the long run
  5. Gryphon001
    Gryphon001 Active Member
    303
    44
    If you do decide to go aftermarket... make sure you NEVER.... EVER turn on your wipers and lights at the same time. Wait till the HID's are fully warmed up before using your wipers. After several years of wrangling with the issue this is so far the best solution we have been able to come up with... Digital ballasts reduce the chance of a blowout happening but don't solve the issue, as do the CanBus modules.
    In regards to your more immediate problem though... I have never heard of this happening, are you sure you have the appropriate bulb for your housing??? Also it would probably help to know what housing/HID kit/Bulbs you are using if someone here is to help you out.
    Good luck anyways...
  6. Evo_Mic
    Cheers for the info folks, I am using Virtual Daylight HID's in the car with the control units to stop the light coming up on the dash.
    I did ask Audi to price up swapping the headlights in the car but the wouldn’t give me a price & just said £2-3k to do it.
    By the sounds of it the best option will be to buy OE headlights & install them, friend is an Auto Electrician so will help there with the wiring.
  7. percymon
    percymon Member
    156
    Some of the h7 kits have different length glass bulb sections which can foul the shield, a few friends who did hid kits on Porsche 996/986 models years ago had the same issue. Just another thing you have to check before buying a kit.
  8. c_w
    c_w Well-Known Member
    1,163
    87
    Firstly you want to make sure your HID bulbs are the H7R type (not normal H7), the R stands for reflector and means it's suitable for use in a reflector housing. The bulb has a ceramic coating on the the bulb to control the beam. Further to this, you want to use a "short" H7R HID bulb, this is the best one to use as the arc/light source is in similar/same position as the original halogen filmanet. This both keeps the beam pattern similar/same and also the shortness means it doesn't interfere with the "umbrella" on the end sat in the housing.
    Kits like these;
    http://cgi.ebay.co.uk/Xenon-HID-con...arts_Vehicles_CarParts_SM?hash=item35a45722ed
    http://www.parkingsensoronline.co.uk/h7rc-conversion-with-decoders-p-346.html
    Interestingly the usual perception is that projector type housings are the ONLY way you can properly fit HID bulbs but Renault Lagunas and Volvos amongst others use HID xenon lights in reflector housings.
    However the wiper motor seems to be a big issue, some people going through motors frequently, some never failing at all, I have no experience of any HID kits on A3s though!
