2005 A3 3.2 DSG S-line Quattro - lumpy tickover
Nubbjuggler Apr 7, 2012
  1. Nubbjuggler
    Nubbjuggler New Member
    Hi all, totally new to this site, and would like some feedback on a problem with my car.
    When driving along the car runs perfectly, then all of a sudden if I stop at traffic lights for example, the tickover can turn all erratic and lumpy, then I may bunny hop away for a few feet then it clears, and at the next stop its fine and smooth only for it to happen again later on.
    I have only just bought the car but would rather sort the problem myself rather than taking it all the way back to the dealer.
    Any help on this would be appreciated
  2. willowsdad
    willowsdad Sideways
    1,027
    32
    I'm pretty clueless when it comes to engines, but when I spoke to Audi about a service recently I was told that mine hadn't been in to have the coil packs checked under recall. So might be worth a call to Audi on that front as it won't cost you a bean.
  3. Qua3ttro
    Qua3ttro Member
    77
    Can you steadily hold 2000rpm when in neutral? Or do the revs jump up and down when trying?
  4. murran
    murran Well-Known Member
    1,545
    39
    any engine man. lights? still worth checking for codes even if the light isnt on. some codes dont automatically put the light on.
    if its missing the ecu should pick up on which cylinder.
    agreed on the coil pack recall, its worth a phone call atleast!
  5. Nubbjuggler
    Jumps about
  6. Nubbjuggler
    it jumps up and down
  7. Nubbjuggler
    I take it audi will know if this car has been in, and would there be a time limit on the FREE repair, and also I am not the original owner?
  8. marknjayne
    marknjayne Member
    425
    unplug the air flow meter,see if it changes
  9. marknjayne
    marknjayne Member
    425
    where are you..not many people put their location ,if you are close to someone who has vag-com or a scanner they could help
  10. Nubbjuggler
    Im in Worcester, I was just looking on e-bay for a diagnostic tool, but not sure which one to get?
  11. marknjayne
    marknjayne Member
    425
    i will link you to the one i have,its an epic bit of kit...gimmie a mo
  12. marknjayne
    marknjayne Member
    425
    have you unplugged the air flow meter and tried ...if it is something like that you will need to reset the ecu code when you fit new
    click me for the link
    pioneer181 likes this.
  13. Nubbjuggler
    Thanks for that, funny enough that was the one i was looking at. :icon_thumright:
  14. marknjayne
    marknjayne Member
    425
    i also use this for more in depth monitoring etc
  15. Nubbjuggler
    Just phoned Audi Worcester the car is still eligable for free coilpack upgrade so its booked in for wednesday. :respekt:
  16. shariain
    shariain Well-Known Member
    1,182
    190
    Also check and see if it needs the ecu update and get this done at the same time as your coil packs there is info on here on the software update.
    Here is the info you would give Audi
    Engine software update
    Tpi 2010289/3
    Sum 8P01A005
    Update disk 4F0906961N
    You might have to pay to get this done.
