2005 A3 2.0 TDI BKD - Torsion Timing Value!!!
darthmal Oct 6, 2011
  1. darthmal
    darthmal New Member
    Hi chaps,
    Ok I've read nearly all the threads on this but i still cant figure it out...!
    Got a 2005 A3 2.0 TDI BKD code. Got VCDS 10.6 and cable.
    Go to Engine
    Measuring Blocks
    Group 004
    ... but the basics settings button is greyed out!
    If I go to basic settings instead of measuring blocks, ive only got two options, egr and charge control or something.
    So how do i get to basic settings so i can check the torsion value?!
    (I get all the values when i go to measuring block -> group 004, but i've read that these are the values once the ecu has corrected it.)
    How do I see the real values?!
    Thanks for the help!
  2. NHN
    29,352
    1,720
    If its a genuine interface, then contact support@ross-tech.com who would be happy to help you with info on this.
  3. darthmal
    darthmal New Member
    Well Im assuming its genuine as its got 'genuine ross-tech' moulded into the obd connector :S but ill ask my colleague who im borrowing it off.
    Anyway got it sorted. The values in 'measuring blocks' are the real values.
    got 0.0kw torsion timing, -0.5 under load, which is right i guess. might advance it slightly to see what happens!
