2005 3.2 re-map
Discussion in 'Awesome GTI' started by nwhiteley, Jun 10, 2007.
  1. nwhiteley
    nwhiteley Member
    Jun 1, 2006
    196
    Hi Sarah/Ade, having bought items from yourselves in the past, i am going to use your services again. Im about to buy a 2005 3.2 manual a3 and would like some info and pricing about the re-map and other tuning options for the afore mentioned car.
    IE, is there a remap available, what are the gains (probably small), how much will it cost, and what about induction and exhaust options, etc.
    Neil
  2. Google AdSense Guest Advertisement
    to hide this advert.
  3. awesomeade
    awesomeade Member
    Nov 5, 2003
    46
  4. AwesomeSarah
    AwesomeSarah Member
    Oct 24, 2006
    726
    Hi Mate
    Yes as Ade said
    I did try to post earlier , but my computer crashed and wiped it off before I could post :(
    It is not a good engine for mapping so the main gains would be the exhaust and the induction kit
    Hope that helps and Ade`s little bit too?
    Sarah
  5. marms
    marms Member
    Jan 13, 2007
    833
    What has Ade's little bit got to do with anything?:)
  6. nwhiteley
    nwhiteley Member
    Jun 1, 2006
    196
    Do Carbonio not do a induction kit for the 3.2, or will the TT or R32 kit not fit?
  7. awesomeade
    awesomeade Member
    Nov 5, 2003
    46
    The R32 carbonio physically fits to the engine but as far as i'm aware doesnt go down into the cavity behind the wheelarch.
  8. nwhiteley
    nwhiteley Member
    Jun 1, 2006
    196
    Pity, it looks like a good bit of kit.
    Regarding the Milltek exhaust, is it possible to just get the back box and tail pipe assembly, or is it only available as a cat back kit?
  9. Peter Hopper
    Peter Hopper New Member
    May 27, 2007
    13
    better go for the whole system from the cat back because you will need to sleeve the original pipe work to the new 2.5'' pipe work and the more connections the more the leaks.
    Regards
    Peter
  10. awesomeade
    awesomeade Member
    Nov 5, 2003
    46
    Peter is correct... it is possible to just get the backbox but it will need to be sleeved... we also find when the pipework changes up a size that far back the backbox can be droney.
