2004 S4 replacement engine?
Simon S4 Feb 25, 2011
  1. Simon S4
    Simon S4 Member
    55
    What is the cost of a replacement engine for a 2004 S4 (the 4.2 V8)? Have got a nasty rattle and am just looking at diiferent scenarios, including worst case..
    Thx
  2. kite
    kite Member VCDS Map User
    677
    The V8 is known to suffer a start up rattle due to the chain tensioner, you may not need a complete engine..
  3. Simon S4
    Simon S4 Member
    55
    Hi kite, it isnt a start up rattle, it is a rattle which an engineer at my garage picked up as they tested the engine oil pressure at 2000 rpm... and the pressure came out quite low at 2 bar...he didn't feel he could test at 3500 rpm as this could cause more damage... so thats why i am enquiring about worst case scenario... ;-(
  4. hades-
    9,481
    646
    iv see them around for 155 / 2k
    then ftting and parts it could need doing at same time as it wont have any history
    cant your man sort the problem without replaceing the engine ?
    could just be the pump needs replaceing
  5. Simon S4
    Simon S4 Member
    55
    Yes, the man actually found a way - drained oil, cleansed/flushed engine, changed oil filter, put in new oil and the pressure is normal... fingers crossed that's 'all' it was... sounds like a blockage somewhere - is this common on 'older' cars? or a sign that the car has been used for short journeys? or oil hasn't been chaged often enough? not sure...
  6. hades-
    9,481
    646
    keep an eye on it if it was blocked it will block again
    and a new pick up pipe aint gona cost that much
  7. Simon S4
    Simon S4 Member
    55
    thanks for tip bez101 - how much approx? and what exactly do i have to ask for ('new pick up pipe'?)?
