2004 audi s4 real max power ?
adamss24 Oct 17, 2013
  1. adamss24
    adamss24 Well-Known Member
    4,584
    407
    As per title, just bought a tidy 2004 s4 saloon which is in need of some love and i am wondering what are the max power gains that can be had from the v8 NA engine ? It's missing a few bits: front centre armrest, had RNS E at some point but has been removed and it looks like it's been mapped at some point- the engine is rather loud with the factory exhaust ! Good thing is a manual and with a few cosmetic tweaks it can be made a looker ! I wasn't in the market for a powerful v8 saloon- an estate would fit my bills a bit better but i will give it a try for a little while ! The engine is healthy and is quite low mileage, will post a few pictures when i get it back home from it's previous owner !
  2. matthew999
    matthew999 Member
    149
    What going on, it's not a diesel and its naturally aspirated. U feeling alright mate!
  3. adamss24
    4,584
    407
    I will give it a try for a short while, it's supposed to be mapped to about 380Bhp and it's not bad overall ! It will have a hard time bettering the a6 on a motorway drive, that a6 is an animal, pushed it to speeds over 140Mph and still averaged 45Mph on m1 ! Collecting the s4 this weekend, could not be ***** to tow it today- just went to see it and then bought it !
  4. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    it all depends on what you do to it as to the gains
    normally aspirated and tuned well they are capable of in excess of 400bhp supercharge it and you are closer to 525bhp on a stage 1 map with stage 2 still in devolpment and looking at nearer 600bhp .... unfortunatly the clutch wont last 2 minutes at this kinda power unless you have the tiptronic version in which case its close its near its limit but capable of holding its own as its the same as an rs6
    standard exhaust with a re-map will be around 350-360 if its a very good map if its a cheap one closer to the bottom figure
    the standard exhaust is very restrictive indeed this should be the first thing replaced if your after more performance
    milltek cat backs work very well , but the biggest improvement is from removing the pre cats .... be aware of two differant version
    resonated and non resonated
    resonated has an extra silencer which quietens the exhaust down , but its still loud and growls
    non resonated has no silencer and is very loud all the time , but drones badly at motorway speeds
    air filters do not work on the car , so leave the standard one well alone
    Inertiauk likes this.
  5. adamss24
    4,584
    407
    Thanks for suggestions, i do know a thing or two about tuning and this won't go too far to be honest, i reckon 380 Bhp is plenty fast enough for day to day drive and going fast cost money ! As per clutches i do have now 700 Nm of torque running trough a stock 01E gearbox and Sachs SRE/Loba rs4 clutch and it holds pretty nicely- a little shudder on take off but easy to live from day to day... I think the stock Getrag manual gearbox will hold better than any auto gearbox- i am not launching any of my cars from traffic lights or take them at Santa Pod ! Matter of fact i have a b5 rs4 clutch specified to go over 550Bhp on one of my other cars, i could use that with a custom SMF and i'm sure it will hold whatever that engine can muster.
  6. Reload
    Reload Bird is the Word!
    367
    49
    Pretty good for a Friday afternoon on that road ;)
  7. dualmono21
    1,138
    the gearbox isnt the problem , its the clutch which cannot handle it unfortunatly they are weak on the manuals
    as said the clutches in the auto or tip gearbox are fine but on there limit , but the one in the manual will not last two minutes
    and is usually replaced if going down the supercharged route
  8. dsmclark40v
    dsmclark40v Member
    744
    Really? The JHM supercharger stage 1 is only about 420bhp. They say any more than that and the rods bend. As much as I love the S4 and miss mine I think your figures are a bit on the high side.
  9. dualmono21
    1,138
    Yes really
    What i have quoted is power at the crank the same as the manufacturer quotes
    There are several you tube videos showing cars making in excess of 421 hp at the wheels
    On a dyno
    When you account for 25% transmission loss (typical loss for a 4 wheel drive system )
    This equates to 526.5 at the crank
    So my figures are spot on i
    Hope this explains the differance between crank horseppwer and wheel horsepower
  10. dsmclark40v
    dsmclark40v Member
    744
    Yes I understand the differences between crank, wheel HP and transmission loss I just don't believe that a tuner would be able to get 400 bhp on the crank with just a tune alone. Maybe on a turbo car but not NA
  11. Inertiauk
    Inertiauk Active Member
    574
    29
    A good map with pre cats removed, high flow cats (or complete decat) plus a kilter system should make at least 370bhp at the crank usually more, probably not over 390 though.
  12. adamss24
    4,584
    407
    That's what mine has at the moment: milltek decat pipes, cone filter (will be removed asap) and a remap...did not driven the car yet as it still needs some work !
  13. rjm180
    rjm180 Active Member
    581
    34
    Congrats on your S4 purchase, pics to follow soon we hope.
  14. dualmono21
    1,138
    i never said with just a tune they would go over 400 i said it depends what you do to them as to what gains are achieved
    with just a re-map chip then no , but with the pre cats gutted or de cats and a decent exhaust plus a few other bits then yes over 400bhp is achieveable
    and is being done on a daily basis by companies like jhm
    replacing the air filter system on a b6 or b7 s4 is a waste of time
