2004 8p headlight adjuster toggle does nothing??
RU55SSO Jan 21, 2011
  1. RU55SSO
    RU55SSO Member
    792
    24
    Are they controlled by fuses? I cannot adjust the headlight levels moving the spin toggle does nothing . Note my car isn't auto levelling model or anything just standard sport
  2. RU55SSO
    RU55SSO Member
    792
    24
    Anyone know the relative fuse numbers? Not listed on the plastic flap on my car so I'm a bit lost
  3. mike foster
    3,967
    Fuses are listed in the user manual.
  4. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Russo, according to my Haynes manual, it is fuse 'FC5' which controls the headlight leveling. This fuse is located in the internal (passenger-side) fuse-box, and is 5 amps capacity. Hope this helps. Cheers, Geraldy212
  5. RU55SSO
    RU55SSO Member
    792
    24
    Thanks mate I take it the internal one is under the bonnet? Will check now
  6. RU55SSO
    RU55SSO Member
    792
    24
    Ok had a look there was no fc5 f5 was closest but was 30amp fuse in there checked all other 5s present and was intact. Bit confused now but will have a peek in my manual
  7. RU55SSO
    RU55SSO Member
    792
    24
    Checked my manual and headlight range level is f38 10 amp red fuse. Checked it and it was fine. What else could be a problem?
  8. mike foster
    3,967
    Must be different between 2004 and 2006
    My headlight range control fuse is number 5 in the fusebox to the right of the steering wheel RHD model (in the box behind the end dash panel) and is 10 amp
  9. RU55SSO
    RU55SSO Member
    792
    24
    Mike is this for manual adjustment? Not auto levelling model? For toggle switch next to dash illumination adjuster?
  10. mike foster
    3,967
    Yes - description in the book says - Fuse 5-Automatic headlight range control, AFS control unit (advanced front lighting system)/manual headlight range control 5/10 amps.
    Therefore I can assume that the manual adjustment is 10 amps.
  11. RU55SSO
    RU55SSO Member
    792
    24
    Just checked the driver side fuse box and number 5 was empty although behind the cover it says brake clutch switch. So I take it that it has changed. Mines a 53 plate
  12. mike foster
    3,967
    Ok - so if your fuse is ok then you need to get a diagnostic scan to find the problem.
    There will be an error message that will point towards the problem. If you clear the error message and try the range control again if it doesn't work then another error message will appear.
    Then we go from there.
  13. RU55SSO
    RU55SSO Member
    792
    24
    F38 looks most likely but seems fine
  14. RU55SSO
    RU55SSO Member
    792
    24
    How much and where is the best place to get vcds?
  15. mike foster
    3,967
    Agreed - F38 is the fuse. Totally different from my set up.
    So you need a scan.
  16. mike foster
    3,967
  17. Lewis583
    956
    91
    Well i was in the process of buying a lead off NHN and was quoted £249, would be better to pm him though
  18. mike foster
    3,967
    It was only a guess but not far out eh ?
  19. NHN
    29,327
    1,708
    Could even be the switch itself, ideally you need vcds to see if it has a measuring block to ascertain if its seeing the switch adjustments being made, this is one option.
  20. RU55SSO
    RU55SSO Member
    792
    24
    thats what i was thinking mate. Unfortunately i dont have the funds to get vcds atm. and the one person near me on the list that does never replied
  21. NHN
    29,327
    1,708
    Strange as you have money to buy whats in your sig :p
  22. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,228
    320
    hi soz for the thread hi-jack but on mine above the toggle switch the thing that usually lights up (headlight symbol) has stopped working it was flickering on and off for a while now its stopped working all together is it time for a new switch anybody got any ideas soz again russo2k5
  23. RU55SSO
    RU55SSO Member
    792
    24
    no problem mate. thats fine. and LOL yeah NHN its more of a wish list ;) its because im saving for a holiday with the GF shes the boss. :(
  24. FranA3
    7,228
    320
    my wish list is alot bigger than that haha there are many many things on mine most of which i cant afford yet lol
  25. NHN
    29,327
    1,708
    I would pull the switch out & check for any loose wires 1st.
  26. Khufu
    Khufu Well-Known Member
    5,704
    31
    the reostats sometimes go. I will have a spare headlight switch after i've fitted my xenons. Its basic one with headlight adjuster, side/dipped, front & back fogs.
    New one hasn't got aim adjuster as its for xenons.
  27. FranA3
    7,228
    320
    i had the pannel off while i was fitting my footwell lights but plugged the wire back in firmly i might take it back off 2morow and see if i can see if there is anything obvious
  28. lesteague
    lesteague New Member
    I have the same problem on a 53 plate A3. Fuses are fine, light dimmer works but range control doesn't do anything, also don't appear to have any codes...
  29. NHN
    29,327
    1,708
    Could be headlight motors.
  30. lesteague
    I hate to agree NHN but I think you may be right. Can the motors be stripped and potentially fixed or are they sealed units?
