For Sale 2003 Audi A4 AVANT 1.8T (190) REVO, KW V3, ROTIFORM
tmparry01 Jan 1, 2018
  1. tmparry01
    tmparry01 New Member
    2003 Audi A4 Avant 1.8T (190)
    Akoya Silver
    6 Speed Manual
    Revo Remap
    Hybrid Turbo + TT Injectors
    KW V3 Fully Adjustable Coilover Suspension (Adjustable Height, Bump & Rebound)
    RS4 Rear ARB & 1000Ib Rear Springs
    Rotiform 19” Alloy Wheels
    2x New Front Wings Spring 2017
    FSH (Dealer, Indy & DIY)
    MOT October 2018
    £3950 ono
    History
    30/12/2017- PAGID FRONT BRAKE PADS (~126,000 miles)
    MOT Date tested 4 October 2017
    PASS Mileage124,385 miles
    MOT test number4543 8322 7860
    Expiry date23 October 2018
    25/3/2017- SERVICE + INSPECTION (119,972 miles)
    4/3/2017- VALVE COVER GASKET SET
    2/3/2017- POWERFLEX SNUB MOUNT
    9/1/2017- OSRAM NIGHTBREAKER BULBS
    19/10/2017- REPLACE FRONT BRAKE HOSES (117,984 miles)
    MOT Date tested15 October 2016
    PASS Mileage117,057 miles
    MOT test number8093 3405 9780
    Advisory notice item(s)
    x2 rear indicators slightly discoloured-under trays insecure
    x2 rear flexis corroded-n/s/r/ tyre on limit
    x2 front flexis hoses deteriated slightly
    24/10/2015- SERVICE + INSPECTION (112,324 miles)
    Date tested24 October 2015
    PASS Mileage112,320 miles
    MOT test number4037 0973 6434
    o/s/r indicator slightly discoloured
    x2 front flexi hoses deteriated
    n/s/f cv boot deteriated
    17/4/2015- PAGID F+R BRAKE DISCS+PADS
    1/2/2015- REAR COOLANT FLANGE
    20/12/2014- REVO REMAP (105,535 miles)
    16/12/2014- NEW ALTERNATOR
    6/11/2014- SERVICE + INSPECTION (104,595 miles)
    Date tested3 October 2014
    PASS
    Mileage103,911 miles
    MOT test number2190 9607 4224
    FAIL
    MOT test number6555 0647 4271
    Reason(s) for failure
    Headlamp aim too low (1.8)
    11/7/2014- NEW GENUINE CV BOOT
    14/5/2014- FULL MEYLE CONTROL ARM SET
    7/2/2014- NEW GENUINE BOOT ACTUATOR
    4/12/2013- TIMING BELT, WATERPUMP & FLUIDS (97,996 miles)
    Date tested23 October 2013
    PASS
    Mileage96,719 miles
    MOT test number2282 2699 3230
    Date tested23 January 2012
    PASS
    Mileage93,851 miles
    MOT test number3478 9392 2081
    FAIL
    Mileage93,851 miles
    MOT test number7090 5372 2016
    Nearside Headlamp not working on dipped beam (1.7.5a)
    26/1/2011- SERVICE + INSPECTION (89,477 miles)
    Date tested21 January 2011
    PASS
    Mileage89,472 miles
    MOT test number4353 9152 1058
    Date tested26 November 2009
    PASS
    Mileage81,982 miles
    MOT test number7336 2003 9311
    Date tested17 November 2008
    PASS
    Mileage73,662 miles
    MOT test number4943 8292 8430
    Nearside Front Tyre worn close to the legal limit (4.1.E.1)
    Offside Front Tyre worn close to the legal limit (4.1.E.1)
    Date tested13 November 2007
    PASS
    Mileage64,090 miles
    MOT test number5603 7731 7362
    Offside Front Lower Suspension arm has slight play in a ball joint (2.4.G.2)
    Date tested5 November 2007
    FAIL
    Mileage63,964 miles
    MOT test number2939 8950 7303
    Offside Front Upper Suspension arm has excessive play in a ball joint (2.4.G.2)
    Nearside Rear Tyre tread depth below requirements of 1.6mm (4.1.E.1)
    29/11/2006- SERVICE + INSPECTION (53,999 miles)
    Date tested20 October 2006
    PASS
    Mileage52,673 miles
    MOT test number5027 0349 6246
    Offside Front Suspension arm has slight play in a ball joint (2.4.G.2)
    Nearside Rear Anti-roll bar synthetic bush deteriorated but not resulting in excessive movement (2.4.G.2)
    Rear number slightly discoloured
    FAIL
    Mileage52,673 miles
    MOT test number1522 3359 6231
    Nearside Rear Tyre not fitted in accordance with side wall instructions (4.1.D.1f)
    Nearside Rear Stop lamp not working (1.2.1b)
    26/11/2005- SERVICE + INSPECTION (36,697 miles)
    27/11/2004- SERVICE + INSPECTION (17,950 miles)
