2002 s3 suspension and top mounts what should I get??
Donk1 Oct 26, 2013
  1. Donk1
    Donk1 New Member
    21
    Yesterday I took the s3 out and one of the front springs broke . Im thinking about just changing all the springs and shocks as its done 85k and everything is probably a bit tired now . While I was checking it over today I noticed the front top mounts have also seen better days so I'm going to change them at the same time.
    where's the best place to get new suspension and what should I go for oem or aftermarket . Iv had loads of after market setups over the years and have learnt some set ups have been to stiff for the road and just ruin the handling.
    Also the same for the top mounts where should I get them from and oem or aftermarket .
    The car won't be used on the track .
  2. jojo
    29,001
    3,657
    I'm using ECP top mounts and bearings, no issues, and I have tracked my car.
  3. Donk1
    Donk1 New Member
    21
    Iv had a look round and I'm going to get seat Leon cupra r front mounts and bearings.
    What shocks and springs should I go for I'm not that intrested in coilovers as its not going to be used on the track and don't want to go to low . What are the weitec ultra gt lowering kits like they don't seem a bad price and only lower 20mm
  4. Donk1
    Donk1 New Member
    21
    i had a look on the ecp website but couldn't find the top mounts
  5. jojo
    29,001
    3,657
    I thought I'd have a look myself, and you are right, can't find them online. I got them off a mate who works at ECP using my reg number. I had both new topmounts and bearings.
  6. Sean_S3
    Sean_S3 Member
    324
    17
    I had the Weitec Ultra GT 20mm lowering springs and shocks on my previous S3 and they felt like OEM. My current car has the Koni kit which feel more sporty , they are similar price too if bought from DPM Performance.
    Lemforder top mounts and bearings from GSF are ok if ECP don't have any.
  7. Donk1
    Donk1 New Member
    21
    These are the kits I would consider
    weitec gt coilovers
    bilsteins
    kw v1 coilovers
    buy is really worth the extra money going for the Billy's or coilovers if its not going to be used on the track I'm after something that will improve the handling but not at the expense of being crashy and harsh to drive normally
  8. jojo
    29,001
    3,657
    My Bilsteins are great for the road, not crashy at all, but they are not cheap.
  9. Donk1
    Donk1 New Member
    21
    bilsteins are good and used on a lot of cars from the factory but they expensive for shocks and springs.
    Im leaning towards getting some kw v1's as you can get them for £750 at the moment but are they that much better then say the weitec ultra kit that cost about £480.
  10. Big Al
    Big Al Active Member
    489
    68
    Hi mate
    I'm selling a suspension set - you have a PM!
    Alistair
  11. Donk1
    Donk1 New Member
    21
    Iv had a look on line and found bilstein b12 for £600 new so I'm going to give them a call tomorrow and probably going to order them .
  12. Donk1
    Donk1 New Member
    21
    Iv ordered the Bilstein b12 pro kit from GNJ Motorsport this morning hopefully I receive the kit this week so I can fit them at the weekend.
    Do the b12 kits come with new top nuts , damper sleeves and bump stops ?
    Iv found the following part numbers for the top mounts and the other bits im going to order.
    1HO 412 365A Threaded sleeve
    1ML 412 331 LCR Top Mounts
    1JO 412 249 Top mount bearing
    Are there any other parts that people would recommend fitting at the same time which may get damaged while fitting or would make install easier.
  13. jojo
    29,001
    3,657
    New top mounts and bearings when fitting new suspension is a good idea, as it's all coming off. But of a no brainer for the cost of the parts.
  14. Donk1
    Donk1 New Member
    21
    I thought I might as well do them while iv got it off. I never intended in doing much to the s3 but I knew I would ended up getting carried away iv used a broken spring as en excuse to change all the shocks and springs.
  15. fingermouse
    fingermouse thats me
    4,027
    120
    billy b8s , h&r s[prings -25mm leon cupra r top mounts adjustable rear arms , R 32 ARB jobs sorted :)
  16. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    538
    + a full poly bush kit inc dog bone mount and 4wd alignment :)
