2002 S3 airbox removal, how??
JD09 Mar 2, 2010
  1. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    OK so while trying to remove the top half of my airbox to check the paper filter last night, I was completely beaten by it!
    I know it is purely because I don't know where all the screws/clips are and once I have done it, it will be second nature second time around. I also want to remove it fully from the MAF to use a spray engine cleaner (thanks MikeGTR!).
    Can someone point me to a guide/type it up quickly?
    Much appreciated!
    James
  2. Dani_B19
    9,364
    399
    Undo the two screws that si behined the aribox, they secure the top half to the top, then unclip the maf, unscrew the jubilee clip holding the tip on to the maf, pull the tip off the airbox and there you go, airbox lid off.
  3. JD09
    3,096
    46
    Ah great, thanks. It looked like the airbox was stuck from the front of the engine, thought there must have been clips that I was missing! Got the screws off, but just wouldn't budge!
  4. Dani_B19
    9,364
    399
    It takes some working to get the tip out od the way etc, alos theres a 10mm bolt holding the base of the airbox down just past the screw on the right handside.
  5. jojo
    28,995
    3,640
    There's also a plastic hose thing you need to disconnect near the battery, you need to squeeze the plastic hard and pull, might need a few attempts to get it off if you've not done it before.
  6. JD09
    3,096
    46
    Appreciate that JoJo, thanks!
  7. jojo
    28,995
    3,640
    Thinking about it, it might be part of the lower half of the airbox, might not need to remove the part I mentioned to get the top off, youy will see when you have a look.
  8. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
    Did MikeGTR say you need to spray that stuff post MAF? not pre MAF. You might want to check
  9. JD09
    3,096
    46
    I will need to remove all of the airbox as I want to use a spray cleaner as well, so your advice was helpful fella.
    Cheers.
  10. JD09
    3,096
    46
    Yeah after the MAF, i.e. without the MAF attached? You've got me thinking now. . .
  11. Alex C
    3,297
    373
    yeah, though he did. So you need to remove the MAF from the TIP as well
  12. JD09
    3,096
    46
    OK. I may get a mechanic mate of mine just to stand by with it lol. Means he can control the throttle as I spray as well!
  13. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Dude its really not tricky :)
    I'd undo the jubilee clip holding the MAF to the TIP
    Unplug the MAF
    Disconnect the plugs from the back of the airbox
    Unclip the rubber hose from the bottom left of the airbox
    Undo the 10mm bolt at the back right of the airbox (onto the suspension turret)
    Undo the 10mm bolt from the front right of the airbox (opposite corner to the above one)
    Lift the airbox out, sliding it to the left slightly due to the airfeed going into the wing.
    Then its just a case of undoing the screws that hold the lid down. The lid almost has to open like a hinge, its a lot easier with the airbox off the car.
    Unscrew the 2 phillips screws holding the MAF to the airbox and you're away!.
    Thats how I would do it on my A3, cant see the S3 being that much different :)
    T
  14. Alex C
    3,297
    373
    and make sure nothing gets sucked into the TIP whilst your spraying that gunge in there :)
  15. JD09
    3,096
    46
    Will do, Cookstein :)
