2002 AUM ECU Riveted?
bateman May 21, 2013
  1. bateman
    bateman New Member
    Hi All
    Tried to get at my ECU this evening (2002 A3) but there appears to be a riveted plate covering the connectors?
    Is this normal? I haven't seen this in any reference guides for removal or any other posts I've seen.
    Do the bolts have to be cut?
    many thnks
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    they are shear bolts they alll have this now
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Have you got a further away shot? s3 ecus pull straight out ...
  4. s3dave
    10,110
    736
    Wonder why? if thats the case you will have to tap them around with a centre punch
  5. bateman
    bateman New Member
    I couldn't better a better angle for a photo. I have seen threads mentioning this kind of thing on newer Golfs etc but not an 8l.
    I've got an AGU A3 as well and that doesn't have this so wonder why the difference
  6. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,187
    Probably to stop people messing around with things they shouldn't :)
  7. Broken Byzan
    13,237
    466
    Seen it a few times, not sure why some do and some don't. They are a pain. Dremel a slot, grind them off, chisel, centre punch etc
  8. <tuffty/>
    21,879
    4,202
    Normally cut a slot in them and screw them out... shouldn't effect mapping as it can be port flashed
    VAGs started getting these around 2002 on... seen a few now... mainly TT's but have had an S3 or LCR (can't remember which) in with this too...
  9. jojo
    28,998
    3,652
    I can confirm that an 2000 AUM A3 doesn't have this, as I removed an ECU from one last week.
  10. badger5
    9,602
    2,060
    later ones seem to have this. pia
    grinder slot and heat to loosen the loctite also used on the shear bolts required
    PIA to do
