2001 A6 Heater Control Unit Removal
EV2UK Nov 7, 2009
  1. EV2UK
    EV2UK New Member
    Hi guys.
    I've just bought a 2001 A6 and the buttons on the heater control unit are all worn, my question is, if I were to get hold of another unit is it easy to remove.?
    The car has a Bose double DIN stereo if it makes any difference..
    Thank you..
    ..Tony..
  2. Cockney Boy
    Cockney Boy Member
    483
    It will be a straight swap, im not too sure about the 2001 model, but certainly after 2005 (C6) if you change the climate panel, it will go into Component protection. This can only be removed by an Audi dealer. They will probably charge you half hours labour to do this.
  3. EV2UK
    EV2UK New Member
    Thanks for your reply, what will happen if "Component protection" happens, what does this mean and I guess the heater and air con will not work..?
    ..Tony..
  4. Cockney Boy
    Cockney Boy Member
    483
    Yes that is correct, the car thinks a stolen unit has been fitted, so it goes into CP. Only an Audi Garage can get this fixed.
