2001 A4 Starting problem/hand brake issue
vincenzo_2k Oct 9, 2010
  1. vincenzo_2k
    vincenzo_2k New Member
    24
    Hi all
    I have a problem starting my car, that I know is related to the lights but am unsure what part needs to be replaced? It will only start with parking lights on. I read on another forum that it is the headlight switch? What is that? a fuse? or the part for turning on the lights? Is anyone aware of the issue I am talking about? Is that the right part?
    Recently the handbrake is giving an intermittent problem- it has stopped engaging, i.e. there is no tension at all, although it does eventually work. Its just a bit wierd, especially after starting problem.
    ANy ideas?
    Is it likely another electric fault?
  2. quattrojames
    14,050
    577
    Its the headlight switch itself, the bit you turn.
    I don't think the handbrake will be an electrical problem though, more likely a cable/caliper issue.
  3. chancer
    chancer Member
    114
    Handbrake will be seized linkages on the rear callipers. I freed mine a few times before finally giving in and fitting new rear callipers
  4. Garfie
    Garfie Member
    179
    Watching this with interest as I have also found that without any lights on my 130 Tdi takes a few cranks to start but with the lights on it starts straight away.
    What info have you found relating it to the headlight switch as this is all news to me?
  5. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    do a search
    about 2 months ago i posted about it as did someone else there is about 3 or 4 posts flying about!!
    it is a short in the light switch in the off position that causes the problem the light switch is about £120 from audi
  6. vincenzo_2k
    24
    Thanks for that lads. Its the switch itself?? damn, hoped it was a fuse somewhere.. A mechanic told me about it but it got a bit technical for me :)blink:)so i just picked up to try starting with parking lihts on and he guaranteed it would start. A fault unique to this a4 series?
    So £120 from Audi?? Wow, might look for a used part if i can.
    And the handbrake is down to (rear) calipers? That ties in well actually. Thanks a lot! Great help guys!:applaus:
  7. gizabit
    gizabit New Member
    weird is that. i just changed my light switch and now seem to be having starting problems. i think i will try putting in the old switch
    just to see what happens
