2001 a3 fluctuating idling
JamieT_a3 Feb 17, 2014
  1. JamieT_a3
    JamieT_a3 Active Member
    114
    25
    Hello guys,
    I've got a 2001 a3 1.8T and suddenly I've been having fluctuated idling like it's trying to stop the car from stalling , also the car stalled twice in 3rd doing roughly 30mph for no reason but the weird thing being one day the car will drive absolutely fine with no problem but then the car can feel sluggish in 2nd/3rd on another day ?
    Anyone had similar problems or any one know what it might be ?
    Not the most technical with cars but any advice would be great.
    details on the car is 1.8T
    2001
    56000 miles
    cheers ,
    Jamie
  2. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    25,712
    8,792
    Hi Jamie, welcome to audi-sport.net. Have a read through the faqs thread at top of this section. Enjoy the forum. :) x
  3. <tuffty/>
    20,847
    3,687
  4. JamieT_a3
    114
    25
    Cheers for the reply!
    Is there a easy way of checking for leaks ? Or is it just best to get it plugged in ?
  5. <tuffty/>
    20,847
    3,687
    Smoke test is the best way although not many garages seem to have the kit to do it... visual checks for splits etc... oily areas are usually a sign as oil is supposed to be on the inside of the engine not the outside...
    If it looks 'wet' then its most likely got there from a leaky pipe
  6. JamieT_a3
    114
    25
    Got my car checked out and had a servo hose with splits all in it , that's been replaced but still having the same problem
    When I put my foot down...
    Car through up a few codes
    My mechanic have me the following codes
    P1297
    P1137 - intake leak / d.v valve
    Any ideas why these codes are being thrown up or where the intake is common for leaking ?
    Any help would be great !
  7. willh92
    willh92 Active Member Audi S1 Team Brilliant Black
    329
    49
    the dv is a cheap and easy replacement. just done mine - £36 from Audi and ten mins to swap it over.
    have you checked all the vac lines under the inlet manifold? there is one that runs from a nipple at the bottom of the inlet to the left hand side. Check all the pipes that come off the TIP also, as these can be prone to leak/split.
  8. JamieT_a3
    114
    25
    Thanks for the reply and i popped the hood earlier and I could hear a little hiss by the manifold so I think that May be the problem , also do you think it could be the MAF Sensor ? I'm not the most technical with engines so it's going back to a garage in the next few days , also is it safe to drive or will I do further damage ?
  9. epox
    epox Active Member
    772
    74
    unplug the maf and see if it runs better ot the same
    mark
  10. JamieT_a3
    114
    25
    Cheers for the reply ! And if it was a faulty sensor would taking the electrical connection off make it run properly on idle ?
  11. JudderMan
    JudderMan Well-Known Member
    1,003
    164
  12. epox
    epox Active Member
    772
    74
    I believe the car defaults to preset maps, worth a try, mine went and idle was ****. Nothing to loose by giving it a try. Does sound like a split hose though
  13. JamieT_a3
    114
    25
    Hello guys ,
    had a thorough look on the vac pipes and joints and could not find a thing , so after my drive home from work today I decided to unplug the MAF sensor whilst the car was still running and the idle didn't change one bit.
    is the idle supposed to change or the engine cut out ? Is the sensor not working ?
    Any advice or help would be appreciated !
  14. matt blowen
    matt blowen Member
    181
    If i unplug my maf while the car is running it cuts out?
  15. Marshall878
    Marshall878 Member
    134
    30
    If you unplugged the MAF and there was no change in the idle, it suggests the MAF is shot.
  16. JamieT_a3
    114
    25
    New maf sensor it is then, anyone got the part code to hand ?
    cheers all
