2000 S4 torque wrench trivia
Matt82 Nov 26, 2009
  1. Matt82
    Matt82 Active Member
    2,365
    you are allowed to cheat with a haynes manual
    water pump bolts
    stat housing bolts
    pas pump pulley bolts
    crank pulley bolts
    cambelt damper bolts
    lever bolts
    tensioner roller and guide roller bolts
    ribbed belt tensioner bolts
    ribbed belt guide pulley bolts
    vscious fan bolts
    the person with the most correct answers wins a toy :rockwoot:
  2. aragorn
    18,608
    871
    I tend to go with "tight" for everything bar the crank pulley.
    It goes to VFT.
    On a serious note, its not in the A4 haynes as it doesnt cover the V6. I'll have a look on etka in a bit and see if its in there.
  3. Matt82
    2,365
    crank pulley bolts should only be 20nm or so! they dont need to be he-man spec
    ekta should only show parts etc
    i need elsawin, which i think my brother downloaded for me, but hes in hospital at the mo.
    no one else have elsawin here?
  4. aragorn
    18,608
    871
    i have both, just used the wrong name.
    The big bolt in the middle of the crank pulley is normally done up to eleventy-billion NM + 180degrees for good measure, but maybe you havent removed that?
  5. Matt82
    2,365
    nah, i didnt need to remove that (thank god)
    the one on the front of the 928 was 290nm, 27mm with a breaker bar (that flexed at least 30*) with a 4ft section of exhaust for extra leverage
    i had to have the dogs bed on the wings with a load of blankets in case something gave way. it made an almighty crack when it eventually came undone. i need a buy a new torque wrench to get it done up again properly
    as for the audi, any info anyone can give would be great. im hoping to reassemble it all tonight
  6. Matt82
    2,365
    bump... come on you slackers.
    audi have confirmed that my bits have arrived, im ready to start reassembly tonight
    milltek exhaust is available now too
  7. Matt82
    2,365
  8. Broken Byzan
    13,237
    466
    Toothed belt sprocket to camshaft 55 Nm
    Idler wheel 45 Nm
    Toothed belt tensioning roller 20 Nm
    Pulley to crankshaft 20 Nm
    Toothed belt tensioning element 10 Nm
    Central bolt 1) to crankshaft 200 Nm + 180°2)
    All "borrowed" from Elsawin
  9. aragorn
    18,608
    871
    Etka doesnt provide a big list, just tells you them as you go thru the procedures:
    Tightening torques
    55 Nm
    Idler wheel
    45 Nm
    20 Nm
    20 Nm
    10 Nm
    200 Nm + 180°2)
    Thats some of them, i cant be ***** raking out any more, theres simply too many pages.
  10. Lee Goodall
    Lee Goodall Active Member
    2,279
    I thought central bolt to crankshaft was tighten until car moves/wheels spin!! lol
  11. Broken Byzan
    13,237
    466
    ^^ On my car it is, since i had one come loose and cost me a head. A dab of loctite blue and torque wrench/bar set on VFT
