2000 Audi A3 - Airbag light on - VAGCOM'ed
sjokolademelka Dec 16, 2006
  1. sjokolademelka
    sjokolademelka Member
    37
    Hello fellas,
    We just recently autoscanned my friends car with vagcom just to check for faults (at this time the airbag light was not on).
    We then made a log, cleared all faults, which was resistance errors at airbag module and alarm triggered by interior sensor error.
    However, after we cleared the DTC's the airbag light now lights up and shows the same 5 faults.. while trying to clear it it still comes back right away. Anyone has got any ideas what can be wrong? A little weird that all of the airbag moduls have resistance problems so I wonder if this is caused by something else?
    Anyone, please?? :sos:
    First scan:
    Saturday,16,December,2006,12:45:42
    VAG-COM Version: Release 607.3-UD
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    Address 01: Engine
    Part No: 06A 906 018 CJ
    Component: 1.8L R4/5VT MOTR HS D01
    Coding: 04000
    Shop #: WSC 06435
    No fault code found.
    Readiness: N/A
    Address 03: ABS Brakes
    Part No: 1J0 907 379 Q
    Component: ABS/EDS 20 IE CAN 0001
    Coding: 13504
    Shop #: WSC 06435
    Address 08: Auto HVAC
    Part No: 8L0 820 043 M
    Component: A3 KLIMAVOLLAUTOMAT_D77
    Coding: 03140
    Shop #: WSC 06435
    Address 15: Airbags
    Part No: 8L0 959 655 J
    Component: Airbag Front+Seite 3008
    Coding: 00104
    Shop #: WSC 06435
    5 Faults Found:
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
    32-00 - Resistance too High
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
    01218 - Side Airbag Igniter; Passenger Side (N200)
    01217 - Side Airbag Igniter; Driver Side (N199)
    00588 - Airbag Igniter; Driver Side (N95)
    Address 17: Instruments
    Part No: 8L0 920 900 C
    Component: AB-KOMBIINSTR. VDO D11
    Coding: 00144
    Shop #: WSC 00000
    Component: AUZ7Z0Y1482647
    ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1482647
    Address 35: Centr. Locks
    Part No: 8L0 862 257 G
    Component: ZV-Pumpe, DWA, Funk D11
    Coding: 15178
    Shop #: WSC 06435
    4 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    00956 - Key 2
    09-00 - Adaptation Limit Surpassed
    Address 45: Inter. Monitor
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00000
    End --------------------------------------------------------------------------------------------------
    Second scan:
    Saturday,16,December,2006,13:30:47
    Address 01: Engine
    Coding: 04000
    Shop #: WSC 06435
    Readiness: N/A
    Coding: 13504
    Shop #: WSC 06435
    Coding: 03140
    Shop #: WSC 06435
    Address 15: Airbags
    Coding: 00104
    Shop #: WSC 06435
    5 Faults Found:
    32-10 - Resistance too High - Intermittent
    Coding: 00144
    Shop #: WSC 00000
    Coding: 15178
    Shop #: WSC 06435
    Coding: 00001
    Shop #: WSC 00000
  2. Uwe@Ross-Tech
    Uwe@Ross-Tech Member
    130
    Just a guess: Loose connection at the airbag module?
    -Uwe-
  3. sjokolademelka
    37
    Hey,
    Yeah, thanks - we've been thinking about the same. The only strange thing is that the airbag light was not lit when we started the scan, only after we read out the DTC's and deleted them.
    All my intuition says it has got to do with the control unit since it shows problems to all airbag units / belt tensioners.
    It's just that it was an unfortunate coincidence having the airbag lamp show up after a scan.
    Now I know why they say if it's not broken, don't fix it... :puke2:
    Anyway, thanks for the quick reply Uwe. :thumbsup:
  4. Uwe@Ross-Tech
    130
    I've seen other conicidences that are just as strange that were unrelated to scanning the car.
    Actually, passeger's front airbag isn't showing in the list, so it's not ALL of them.
    Have a look in the measuring blocks.
    Group 001 should be:
    Driver's Bag | Passenger's Bag | Driver's Tensioner | Pass. Tensioner
    Group 006 should be:
    Driver's Side Bag | Pass. Side Bag
    Each of these should be "Correct" or "Too high" or "too Low". There's a couple of other possibilities too. In any case, have a look there.
    -Uwe-
  5. sjokolademelka
    37
    Will do, thanks a bunch Uwe!
