2000-2000.5 LED Lights
AndyC Jul 1, 2014
  1. AndyC
    AndyC Moderator Staff Member Moderator
    719
    OK!.
    so all lights work fine in std trim
    replace front sidelights with std LED, no problem
    replace stop/tail with led and you get error on dash.
    replace with can error free led and sides dont work, brake does, you still get error.
    tried 2 different can error free led , same problem
    turn the bulb round to reverse stop/tail and sides work, brake doesnt..
    confused .com
  2. aragorn
    18,129
    763
    Front Sides dont have any "monitoring" so you can do what you like there.
    Rear tail and brake both have current monitoring, so any replacement lamp needs to use the same amount of current as the standard filament bulb.
    Sounds like faulty/****e stop/tail lamps, but since theres no advantage over the filament bulbs you might as well just fit the standard ones and be done with it. They're cheaper, work properly and wont fail inside 6 months when the resistors burn out.
    Oranoco, AndyC and jbh like this.
  3. AndyC
    719
    Resistors do get f ing hot
    std resistance is 66ohm
    the can ones were way above that
  4. AndyC
    719
    Out of interest can you switch off the monitoring in VAG Com?
  5. aragorn
    18,129
    763
    No, its not controlled by a microcontroller, and its not programmable. Its just a electrical circuit that detects the current flowing and provides a "good" or "bad" signal to the cluster as it sees fit.
    You can probably rewire bits of the car to get round it, but it really is totally pointless unless you've fitted LED rear light clusters or something. The retrofit bulbs make no sense other than when they're white, and the LED's give a nicer color, like sidelights and numberplate lamps.
    I fitted some to the number plate lamps on both my cars last year, and they failed within 6 months, all four of them with the same symptoms; fried resistors. Realised it was pointless and binned them off for standard bulbs again.
  6. AndyC
    719
    its more of me playing at the moment.
    i like the response time of the LED as well... very fast flash etc...
    however I still cant understand why the circuit wont drive the sidelights with the CAN resistors in them.
    on the bench both light no problem, in the car only brake works......!!!!!
    gotta be a load issue... but how!
  7. aragorn
    18,129
    763
    It must be a wiring issue with the dual filament bulbs.
  8. AndyC
    719
    std bulbs work fine.
  9. aragorn
    18,129
    763
    yeh, i mean internally in the LED ones, they must be doing something funky inside.
  10. AlexA4Avant
    AlexA4Avant Active Member
    626
    105
    43
    I have had the same problem my ones the Leds just about on swapped the fuse from 5 to 10 amp no difference. They only work with the ignition on aswel
  11. Oranoco
    Oranoco Well-Known Member
    3,859
    381
    I can't echo the sentiments strongly enough. Bung some LED sidelights in if you like (I keep a bag of spares in the glovebox) but elsewhere I really wouldn't bother as there is just no benefit to them over a standard filament bulb.
